MC2150 + HEI Upgrade Makes Moose Happy - Page 5 - JeepForum.com
post #61 of 94 Old 06-20-2006, 01:06 PM
wraithyjeep
wraithyjeep's Avatar
are you nuttered yet?
the emissions computer controls your timing still if your not
and seeing how you have disconected a bunch of things that relate to the carter feed back carb this could be part of your problem.
Silver Rubi JK unlimited.
89 YJ, 4.2, 5 speed, 2" lift, 235 75 r 15 M/T. CRT's HEI, MC2150 1.08, OBA, 120V inverter. removable Light bar, 10 hella lamps, trail rack w/ jerry cans, champion winch, high lift jack, C.B., lined tub. H4 Conversion headlamps, reveiw mirror w map lights. royal blue with matching trailer.
wraithyjeep is offline
post #62 of 94 Old 06-20-2006, 01:10 PM Thread Starter
atomicmoose
Just call me Moose
atomicmoose's Avatar
Nutter. DUN.
atomicmoose is offline
post #63 of 94 Old 07-20-2006, 10:22 PM
ltdanyj
Moose, what did you end up finding?
ltdanyj is offline
post #64 of 94 Old 07-20-2006, 11:01 PM Thread Starter
atomicmoose
Just call me Moose
Well, life has gotten in the way of late. Haven't had much time to work on her. I will update once I get a solution.
post #65 of 94 Old 07-24-2006, 02:09 PM Thread Starter
atomicmoose
Just call me Moose
Alright, got some time this weekend and found a bind in the throttle linkage. Seems to have fixed the problem. Now, I just have to get a vacuum gauge so I can tune it.
The HEI install is now on deck. I decided the next project should be a fun one, (Had enough frustration with this one) so I decided to install my LED tail lights. Looking good so far.
post #66 of 94 Old 07-24-2006, 03:48 PM
GiggityJeep
moose I have been scanning htis post have you got it all running now I have just bought the M/C today as me 90 YJ is basically not running and im tired of screwing with it, please post pics or email to me when you done, that would be awsome.... I will be doing this prolly next week, already nuttered and if that was the hardest part as someone said in here somewhere then thigs should be good but like you all the vacuum crap confuses me greatly, wanting to know how it runs...
GiggityJeep is offline
post #67 of 94 Old 07-24-2006, 08:39 PM Thread Starter
atomicmoose
Just call me Moose
I really went with a minimal approach. All vacuum lines are gone with the exception of the vacuum advance on the distributor, and the PCV lines.
Here are some pics of my progress:
She is running good so far. Hell, she stays running at idle. That in itself is an improvement. I still have to adjust the timing and tune the carb and then do a road test, but I am happy so far.
If you have any specific questions once you start, just holler. I will do my best to answer questions and there are a few guys on the board here who are very helpful and have done this swap.
post #68 of 94 Old 07-27-2006, 03:28 PM
wraithyjeep
well moose how is it?
I have a HEI kit coming next week.
time to get rid of more wires!
tear the 2 computers and wires and looms.
TFI was good but just doesn't seem great I have a stumble at cruising in 5th with little power and when I adjust the timing to get the top end power back I get a lot of pre-ingniton spark knock so the HEI kit I ordered has adjustable vacuum advance built into it.
cheers
post #69 of 94 Old 07-28-2006, 01:17 AM Thread Starter
atomicmoose
Just call me Moose
cheers
She puuuuurss...and I didn't even out the HEI in yet. Can't wait to get to that part.
post #70 of 94 Old 08-10-2006, 09:43 AM Thread Starter
atomicmoose
Just call me Moose
Quick question....
What port on the carb did you run to the vacuum for the front axle disconnect?
Thanks!
post #71 of 94 Old 08-10-2006, 10:18 AM
wraithyjeep
manifold vacuum
off the intake manifold
if you run ported then at wide open throttle there is a chance that your axle will disconnect.
post #72 of 94 Old 08-10-2006, 10:46 AM Thread Starter
atomicmoose
Just call me Moose
manifold vacuum
the intake manifold vacuum ports is that cluster of 5 right beneath the carb, correct?
post #73 of 94 Old 08-16-2006, 08:24 AM Thread Starter
atomicmoose
Just call me Moose
Just an update:
Had her out wheeling at Rausch this past weekend and had a great time! The carb performed flawlessly even on steep inclines. Couldn't ask for anything more. Can wait to get the HEI installed for some more power. That would be my only complaint, it needs more power, but I may be able to attain this with some more tweaking and the HEI.
As a side note, the manual choke is a nice addition and doubles as auto throttle quite nicely.
Hoping to start the HEI soon.
post #74 of 94 Old 08-16-2006, 08:49 AM
wraithyjeep
Originally Posted by atomicmoose
Just an update:
YA got my mc2150 working dreat and my HEI works good now too, manual choke is nice I like it. I will be adding a hand throttle though. just another item I have found that I could use in some situations to keep the revs up and to prevent having to turn the key and able to brake and clutch and move forward all in one shot would be worth it to have.
post #75 of 94 Old 08-16-2006, 08:52 AM Thread Starter
atomicmoose
Just call me Moose
Hand throttle is still in my future as well.... just nice to be able to use the choke as well to keep the revs up.
MC2150 upgrade Vacuum line looke right? Matsuno YJ Wrangler Technical Forum 3 05-25-2009 10:37 PM
new gears = makes me happy ballallday89 Wrangler General Discussion 4 03-17-2009 12:37 AM
Hunting Moose with a TJ (Lighting question) canuck_bob TJ Wrangler Technical Forum 5 08-13-2008 01:21 PM
Some help with a MC2150 MetZenDS YJ Wrangler Technical Forum 26 09-15-2007 12:48 PM
help mc2150 volcom3375 YJ Wrangler Technical Forum 9 11-24-2006 09:38 PM
