MC2150 + HEI Upgrade Makes Moose Happy - JeepForum.com
post #1 of 94 Old 06-01-2006, 10:32 AM Thread Starter
atomicmoose
Just call me Moose
atomicmoose's Avatar
I finally took the plunge and ordered the MC2150 and an HEI upgrade kit. Once the parts arrive and the swap ensues, I will post pics and progress.
Anything you fellers that have done this swap already wanna tell me?
atomicmoose is offline
post #2 of 94 Old 06-01-2006, 10:57 AM
wraithyjeep
wraithyjeep's Avatar
I have mc2150 1.21 ( usually found on 5.8L) had to switch out the high speed valve for one from a 5.0L
I have the TFI pretty happy with the combo
works really well now that i have tweaked things.....that is part of the fun.
Silver Rubi JK unlimited.
89 YJ, 4.2, 5 speed, 2" lift, 235 75 r 15 M/T. CRT's HEI, MC2150 1.08, OBA, 120V inverter. removable Light bar, 10 hella lamps, trail rack w/ jerry cans, champion winch, high lift jack, C.B., lined tub. H4 Conversion headlamps, reveiw mirror w map lights. royal blue with matching trailer.
wraithyjeep is offline
post #3 of 94 Old 06-01-2006, 12:12 PM Thread Starter
atomicmoose
Just call me Moose
Well, I bought a complete kit from a dude on eBay. I don't really have the time to go junk yard diving and then time to fiddle with everything to make it work.
I just wanted to take it out of the box, and hook it up....basically. I know that work is involved, just didn't want too much fuss. Same deal with the HEI kit.
post #4 of 94 Old 06-01-2006, 12:33 PM
wranglerkid16
hes not that great, the instructions arent what there cracked up to be, the carb still doesnt run right(i did the hei install before) all i can say is it is loud under full throttle..the swap is easy to do, you have to make ur throttle work urself, he doesnt explain how to do it, just shows pictures, if i were to do it again, i would of done the kit myself.
1990 YJ 4.2...HEI, MC2150, dupicolor bed lined(inside), ax-15
wranglerkid16 is offline
post #5 of 94 Old 06-01-2006, 01:00 PM Thread Starter
atomicmoose
Just call me Moose
Did you purchase from this guy?
post #6 of 94 Old 06-01-2006, 03:18 PM
blue1989yj
blue1989yj's Avatar
Many here have purchased it from him. I got mine and he was impossible to get through to for questions. He also took well over a week before it was even shipped. The instructions were OK, but a lot of overkill that you had to sift through. This forum is where I figured out the questions I had. There are lots of threads on this site. Read them and you will be fine. It will make a difference in how the jeep runs. I hope to fix the rest of my issues and get her on the road again soon.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #7 of 94 Old 06-01-2006, 03:21 PM Thread Starter
atomicmoose
Just call me Moose
Well, I didn't purchase it for the instructions, just the parts and I figured with almost 2k in good feedback, he can't be that bad. And the price was right.
As the rest of you, I get my Jeep info here.
post #8 of 94 Old 06-01-2006, 08:23 PM
MaineYJ
I have that setup and I'm VERY pleased. There's no real reaso to HAVE to contact the ebay guy with questions....It's not that hard.
87 YJ 258, 2" BL, 33"BFGs, NV3550, np231, mc2100, HEI, CJ Aluminum Valve Cover, and NO computer
MaineYJ is offline
post #9 of 94 Old 06-02-2006, 12:16 AM
Bgeddes
Bgeddes's Avatar
1978 CJ5
Where do you tie in the Hot for the HEI. I am swapping in an engine that came with an HEI installed. The only thing I haven't found is where to connect the hot on the Jeep's electrical.
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline
post #10 of 94 Old 06-02-2006, 09:04 AM Thread Starter
atomicmoose
Just call me Moose
Hey, start yer own thread thar buddy.
post #11 of 94 Old 06-02-2006, 09:05 AM Thread Starter
atomicmoose
Just call me Moose
Originally Posted by MaineYJ
I have that setup and I'm VERY pleased. There's no real reason to HAVE to contact the ebay guy with questions....It's not that hard.
I agree. Can't wait for the stuff to show!
post #12 of 94 Old 06-02-2006, 09:23 AM
wraithyjeep
yup that is the guy i bought from
the 1.21 mc 2150 carb will not work as it requires a differnet high speed valve that works under a different load requirement than the 4.2 can create.
so i had go to the auto part supplier and order a reman carb then get the right high speed off a 302 carb i could have went with a 1.08 but i figure 1.21 for more air flow. now that i have things working right it seems pretty good and i use a lot less fuel.
I also found that a air breather filter housing that goes on the carb from an 85 ford bronco ii with a 2.8 V6 will fit great on the carb. and keeps the filter cleaner longer and keeps water from soaking the filter element. and quiets down the engine as well.
forget amout the electric choke and go with a manual choke.
post #13 of 94 Old 06-02-2006, 09:25 AM Thread Starter
atomicmoose
Just call me Moose
Got the manual choke setup.
Do you have more info on this high speed valve?
post #14 of 94 Old 06-02-2006, 10:12 AM
wraithyjeep
ok real name is apparently power enrichment valve
alot of info can be had here
http://home.earthlink.net/~bubbaf250...rb/carb01.html
lots of links and reading to go through
Power valves
The following table lists Motorcraft part numbers, Ford service part numbers, color coding, and calibrations for Motorcraft 2150 single-stage power valves.
Motorcraft P/N
Ford Service P/N
Color Code
Calibration
CE51 this one is found on a ford 351M/400 standard transmition
C8AZ-9A565-A 81 ford bronco or F150
violet
1112 in/Hg
CE119
D5UZ-9A565-A
orange
1011 in/Hg
CE117 this one is found on pre 79 cars with 351M engines
D5TZ-9A565-B
red
910 in/Hg
CE74 found on ford f150/mustang 302 engines
C0AZ-9A565-A
(plain)
89 in/Hg
CE109
D5GZ-9A565-A
green
78 in/Hg
CE101 Hate to say it but me thinks this is the one for the jeep 4.2
D3AZ-9A565-B pink
pink
6.57.5 in/Hg
CE113
D5ZZ-9A565-A
yellow
67 in/Hg
CE106
D5AZ-9A565-A
black
56 in/Hg
D5DZ-9A565-CA
silver
4.55.5 in/Hg
CE112 found on 85 ford bronco ii 2.8L
D5DZ-9A565-A
brown
45 in/Hg
CE108
D5AZ-9A565-B
white
34 in/Hg
CE110
D5TZ-9A565-A
blue
23 in/Hg
you can order these parts from a carburator parts supply the valve is $6 Walker is the manufacturer
I'm currently using a plain colour and still may need to drop to a lower one
1.21 came with a violet one which is the highest forget about using 5th gear with this valve.
I have a brown one from a 2.8L ford that i may try next
lots of tuning to get a carb to work perfectly for a 4.2L but my set up is #50 jets with a 89 in/Hg power valve (not to ve confused with accellorator pump)
acellorator pump is on the foward face of the carb the enrichment power valve is on the bottom side of the carb.
I have very no stuble on take off minor hardly noticable stubble when at cruise with slight tip in to the throttle and 5th works good at 70mph so that tells me i need to drop my power enrich valve to a lower presure/HG.
but it works for now and i'm happy.
parts catalogue
http://www.walkerproducts.com/Catalo...ord2barrel.pdf
supplier
http://www.swapsupply.biz/catalogmain.html
just give him the part Number and he will supply price or navagate and find price list.
I'll continue to search pick and pull as it cost nothing for me to put the vavle in my pocket. nice to have a yard that cares more about the price of scrap than the potential worth of a part parts price = scrap weight value.
post #15 of 94 Old 06-02-2006, 12:54 PM Thread Starter
atomicmoose
Just call me Moose
Wow! Lots of good info there. Thanks!
MC2150 upgrade Vacuum line looke right? Matsuno YJ Wrangler Technical Forum 3 05-25-2009 11:37 PM
new gears = makes me happy ballallday89 Wrangler General Discussion 4 03-17-2009 01:37 AM
Hunting Moose with a TJ (Lighting question) canuck_bob TJ Wrangler Technical Forum 5 08-13-2008 02:21 PM
Some help with a MC2150 MetZenDS YJ Wrangler Technical Forum 26 09-15-2007 01:48 PM
help mc2150 volcom3375 YJ Wrangler Technical Forum 9 11-24-2006 10:38 PM
