MC2150 Choke Thermostat really needed? - JeepForum.com
post #1 of 8 Old 07-31-2012, 05:01 PM Thread Starter
Lushaholic
I am in Houston, Texas and my buddy is having a pain adjusting the choke thermostat that was paired up with the MC2150 upgrade. Is the choke thermostat really needed? I've read on random internet pages , referring to other vehicles, that it may not even be needed in "hot" areas.
Any ideas?
Chris
Lushaholic is offline
post #2 of 8 Old 07-31-2012, 07:37 PM
4.7stroker
If your idle mixture screws are set right you will still need a choke to start from cold. Adjusting the choke is simple and will stay put when set.
I have no issues with the electric choke over here in NM.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 8 Old 07-31-2012, 08:16 PM
evanjeep
2011 WK
I just got ride of my electric choke and put a manual one on pretty simple
evanjeep is offline
post #4 of 8 Old 07-31-2012, 09:32 PM
zeus87gn
1987 YJ Wrangler
Stroker, this choke coil doesnt seem to work right
If i set it cold, it wont open up enough when warm
If i set it just to open when hot, it wont close enough when cold
But it will begin to close slightly when hot for more than about 30m continuous
?????? WTF?
Bad coil?
Never had this problem with my Holley elec choke
I set it cold and its worked ever since
Chris, yes you need it
The elec is easier than the manual
Not to mentoin youre still wired for it
What you dont need is the water jacket in the intake
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #5 of 8 Old 07-31-2012, 09:38 PM
evanjeep
2011 WK
Well my electric choke didnt work right and me controlling the choke from in the jeep is pretty common sense lol
evanjeep is offline
post #6 of 8 Old 08-01-2012, 09:37 AM
booboowv77
Did you pull the electric choke coil and flip it over? On the 2150 it works backwards from the stock carter.
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #7 of 8 Old 08-01-2012, 09:43 AM
evanjeep
2011 WK
Yea i reversed the carter coil. It made mine run rich and stutter. Now i dont stutter or smell a bunch of fuel
evanjeep is offline
post #8 of 8 Old 08-01-2012, 09:54 AM
zeus87gn
1987 YJ Wrangler
This is a new coil -doesnt didnt think about using the old carter coil
zeus87gn is offline
mc2150 electric choke opening too soon. beachedjeepyj YJ Wrangler Technical Forum 3 02-27-2012 02:01 PM
Adding a Choke Thermostat to a Motorcraft 2100 pkearney06 YJ Wrangler Technical Forum 11 04-17-2010 02:21 PM
mc2150 choke electric help...easy question bcameron1974 YJ Wrangler Technical Forum 1 05-12-2009 12:39 PM
where does the wires from choke thermostat, plug into...? fishmanwill YJ Wrangler Technical Forum 3 03-25-2009 04:43 AM
Choke sticking? Thermostat? hardison1 TJ Wrangler Technical Forum 6 08-04-2004 11:11 AM
