MC2100/2150 bare vacuum lines - JeepForum.com
post #1 of 11 Old 08-24-2013, 01:42 AM Thread Starter
kgb_m3
Was doing some maintenance last night and discovered a vacuum line mess at the charcoal canister. One ripped line and 3 going to incorrect location. I'm running MC2150, nutter bypass and TFi ignition upgrade. Have a trip lined up in a few days and need Jeep running right.
Could someone please post absolute bare minimum way to run the MC carb. I would like to delete the canister out of equation till I get back and buy new vacuum hoses. Then connect everything right. For now what can I do to delete the can? I can't seem to find any diagrams that bypass the canister.
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #2 of 11 Old 08-24-2013, 04:33 AM
Rproject
1987 YJ Wrangler
My canister was out of the equation before I got mine, I actually - somewhat - brought it back after the 2150 swap.
The purpose is supposed to be to collect excess fuel vapors and return them to the tank. All my lines were missing. I connected the vent line on the front of the 2150 to the canister just so I wouldn't have any fuel spill out while off camber. Other than that, I have nothing connected to my canister.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 11 Old 08-24-2013, 08:05 AM Thread Starter
kgb_m3
I see what you're saying. However for now I just want to bypass the can and run only 2 or 3 lines needed to run the truck. I'm assuming those would be brake booster, PCV and distributor. Am I missing anything? There was a pic of minimum vacuum line configuration for MC carb, can't seem to find it...
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
post #4 of 11 Old 08-24-2013, 08:40 AM
roadyrob
1987 YJ Wrangler
theres a diagram in this thread, just eliminate what you don't need.
http://www.jeep-cj.com/forums/f2/210...-1-14-a-16682/
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #5 of 11 Old 08-24-2013, 10:22 AM
jojojeep1
I have one vac line going to the vac advance and that's it , I pluged off the rest of the carb and you can balance a dime on my air filter that's how nice the jeep runs.
jojojeep1 is offline
post #6 of 11 Old 08-24-2013, 04:30 PM Thread Starter
kgb_m3
^^ That's what I want to do as well. Couple of things though, what did you do with your PCV valve? What about carb bowl vent tube, it used to go to canister, do i plug it or leave it open?
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
post #7 of 11 Old 08-24-2013, 04:45 PM
Rproject
1987 YJ Wrangler
I did the same thing. Vac advance & 1 line to the canister for the vent. Everything else is capped.
1996 White ZJ
Rproject is offline
post #8 of 11 Old 08-24-2013, 06:55 PM Thread Starter
kgb_m3
Here's what I got now and it runs great!
PCV going to intake manifold. Distributor to carb. Brake booster to manifold. Carb vent and EGR valve left open. That's it and it runs great. Canister is completely deleted and everything else is capped off.
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
post #9 of 11 Old 08-27-2013, 12:07 PM
vadslram
Front lockup?
That's the only 4 I'm running right now. The tank vent and carb vent both go to the canister but activating line from the carb softened and broke so I just capped it. I know I have to replace it eventually or the canister will get soaked.
vadslram is online now
post #10 of 11 Old 08-27-2013, 02:00 PM
Rproject
1987 YJ Wrangler
Originally Posted by vadslram View Post
Front lockup?
I capped that line at first as well, but my mechanic buddy told me it had to vent, so I ran it to the canister. It's the only thing connected to the canister.
1996 White ZJ
Rproject is offline
post #11 of 11 Old 08-27-2013, 05:19 PM Thread Starter
kgb_m3
Front lockup is manual cable. Vacuum lock failed long time ago.
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
