MC and booster from a blazer.... - JeepForum.com
post #1 of 9 Old 08-31-2011, 06:11 PM Thread Starter
murilstone
1987 YJ Wrangler
So after a long time i finally got my YJ on the road....sorta...
So here is the reason for the post. my brakes SUCK!
thats what happens when it sets for almost 15 years. so i found both the power booster and the MC are bad in my Jeep, i have a booster and MC from my parts car (2002 Blazer)sittin in the basement. i measured the mounting studs and they are real close to matching. The rod that attaches to the brake peddle is the wrong length but i can fix that.
Is there anything that i need to think about to make this work??
Thanx for any input
murilstone is offline
post #2 of 9 Old 09-06-2011, 11:56 AM Thread Starter
murilstone
1987 YJ Wrangler
wont work cant close the hood...
post #3 of 9 Old 09-06-2011, 01:42 PM
Budke
Sawzall.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #4 of 9 Old 09-06-2011, 02:10 PM
Que89YJ
Do the 95 booster mod.
Que89YJ is offline
post #5 of 9 Old 09-06-2011, 03:14 PM Thread Starter
murilstone
1987 YJ Wrangler
Sawzall.
ya, i could paint it florescent green and claim it was a Borg enhancement!
post #6 of 9 Old 09-06-2011, 04:15 PM
hdfxrs91
1987 YJ Wrangler
There's a write-up somewhere about the use of a Ford/Mercury master cylinder and booster that supposed to fit under the hood and give you the braking power you need. A search of the site should help.
hdfxrs91 is offline
post #7 of 9 Old 09-06-2011, 07:55 PM
glenn-91YJ
glenn-91YJ's Avatar
I installed a dual booster out of an 06 TJ. Here's how I did it...
http://www.jeepforum.com/forum/f12/0...my-yj-1177891/
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #8 of 9 Old 09-06-2011, 07:56 PM
TSEJEEPERS
I am running a Mercury master cylinder and a 95 YJ booster, disk brakes front and rear and 36 inch tires.
I can lock them up no problem.
This is my write up.
http://www.mijc.org/phpBB3/viewtopic.php?f=6&t=2821
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 9 Old 09-07-2011, 07:08 AM
Que89YJ
The 95 YJ had a dual diaphram setup like the TJ.
http://www.links4jeeps.com/forum/index.php?topic=9425.0
Que89YJ is offline
350 and drivetrain from a 77 K5 Blazer. 89yjer YJ Wrangler Technical Forum 3 07-18-2009 11:43 AM
Jeep YJ on a Blazer? chip764 YJ Wrangler Technical Forum 6 03-04-2007 10:26 PM
89 s10 blazer into 88 yj mshrmhd YJ Wrangler Technical Forum 7 06-01-2006 12:13 PM
use of K5 Blazer halfline YJ Wrangler Technical Forum 5 09-03-2003 09:38 AM
