MC 2150 problems - JeepForum.com
post #1 of 14 Old 08-16-2013, 08:55 PM Thread Starter
Chase0808
MC 2150 problems
I just got the mc2150 and the carb is great but I'm having some issues. I start it by pumping the pedal once, then starting it. Once it is started, I have to keep my foot on the gas to raise the idle, or it will stall. Once it is completely warmed up it runs great. This only happens when starting from cold.
Chase0808 is offline
post #2 of 14 Old 08-16-2013, 09:40 PM
rambo3489
You have to set the high idle. I do it by pressing my foot to the floor and pulling the choke all the way in. But I have a manual choke on mine. Not sure how it works with an electric choke which is likely what you have on it. But someone will chime in on this.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 14 Old 08-17-2013, 07:10 AM
Rproject
1987 YJ Wrangler
The choke setting and high idle setting is on the inboard side of the carb. You need to set your high idle between 1200-1500. Once you set that, you'll be good to go.
Do you have the adjustment instructions?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #4 of 14 Old 08-17-2013, 08:30 AM Thread Starter
Chase0808
I know where it is but I can't seem to find instructions on adjustments. I bought it from the eBay guy and have the file if the installation but didn't see anything about the high idle.
post #5 of 14 Old 08-17-2013, 09:10 AM
Rproject
1987 YJ Wrangler
OK. Let me find it when I get home this afternoon. Doing some trail maintenance this morning.
1996 White ZJ
Rproject is offline
post #6 of 14 Old 08-24-2013, 11:11 PM
ReDinTX
Did you find the instructions? I have same issue.
-ReD
Fire Lieutenant/Paramedic
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #7 of 14 Old 08-24-2013, 11:17 PM Thread Starter
Chase0808
I just replaced all the vacuum lines and that seemed to do the trick. I still need to change my manifold gasket which causes a little bit of a rough idle. I suggest starting by replacing all vacuum lines.
Sent from my YJ
post #8 of 14 Old 08-25-2013, 08:11 AM
ReDinTX
Will do. While im at it, can I remove some of the emissions vac lines? I guess, what all is REQUIRED to have vacuum?
Vac canister
brakes
axle motor
heater
carb
dizzy
what else?
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #9 of 14 Old 08-25-2013, 08:54 AM Thread Starter
Chase0808
I've heard that you can just run off of 2 vacuum Lina but I've never tried. Mine is and 88 and no longer needs to pass emissions so I'll let you know if I try it out.
Sent from my YJ
post #10 of 14 Old 11-24-2013, 11:06 AM
ReDinTX
Sent from my YJ
any luck?
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #11 of 14 Old 11-24-2013, 11:40 AM Thread Starter
Chase0808
I didn't end up trying it but I'm really considering a fuel injection swap. The only thing holding me back is the fact that the kit costs $1200. I've heard nothing but good about them so that's what I'm going to try. It's the Howell fuel injection kit if you're interested.
Sent from my YJ
post #12 of 14 Old 11-25-2013, 07:53 AM
Old4X
1990 CJ7
Vac canister
brakes
axle motor
heater
carb
dizzy
what else?
Also need the evap canister, PCV, and EGR system
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #13 of 14 Old 11-28-2013, 12:32 PM
krazybob
Sent from my YJ
Never heard anything about an '88 model not having to pass emissions. is that a standard law everywhere, or just your state ? I'd love to delete all the emission stuff if possible. My county in my state of Idaho, does not require any Smog tests, but other counties do, and if I decided to sell my '88, it may limit me to where I could sell it. Maybe I'd better check my Idaho laws :-)
Krazybob,, Mtn. Home, Idaho
My goal, is to die young,,
at a very old age
1988 YJ 4.2 5sp
krazybob is offline
post #14 of 14 Old 11-28-2013, 02:17 PM
Rproject
1987 YJ Wrangler
Emissions testing is very much dictated by age and location. If we lived 3 miles east, our '95 would have needed to be tested. In IL, our '87 is considered too old and doesn't need to be tested anywhere in the state.
1996 White ZJ
Rproject is offline
