maybe fuel pump does not work... - Page 2 - JeepForum.com
post #16 of 27 Old 04-12-2010, 04:26 PM
Mark05059
cps controls spark and fuel delivery. Im guessing that its not the problem.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #17 of 27 Old 04-12-2010, 04:55 PM Thread Starter
ARVENO
..so NO SPARKS....
the rotor ignition turn so i assume that the distributor is working...too
what can i do ???
ARVENO is offline
post #18 of 27 Old 04-12-2010, 04:56 PM
Mark05059
does your check engine light come on when you turn the key?
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #19 of 27 Old 04-12-2010, 05:02 PM Thread Starter
ARVENO
no !!
maybe coil ignition ? or distributor cap ?
ARVENO is offline
post #20 of 27 Old 04-12-2010, 05:04 PM
Mark05059
if you have no check engine light when you turn the key on and the bulb is still good then you have a computer issue.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #21 of 27 Old 04-12-2010, 05:25 PM Thread Starter
ARVENO
the bulbs are all good...that's a bad news...
ARVENO is offline
post #22 of 27 Old 04-12-2010, 06:32 PM Thread Starter
ARVENO
...put new spark plugs and rotor cap...still the same..
how can i check for comp. issue ?
ARVENO is offline
post #23 of 27 Old 04-12-2010, 07:55 PM Thread Starter
ARVENO
..put new ignition coil....same...no sparks...
I give up...
ARVENO is offline
post #24 of 27 Old 04-12-2010, 08:27 PM
RebuildRookie
Sounds like the CPS. make sure its clean and connected. Check with a multimeter if possible . If you have changed all the ignition stuff that's the next thing I would ckeck.
It sends the signal to the controller for spark.
RebuildRookie is offline
post #25 of 27 Old 04-12-2010, 08:29 PM
Mark05059
He has fuel. Its not a CPS issue. He has no check engine light.. its a computer problem.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #26 of 27 Old 04-12-2010, 08:30 PM
RebuildRookie
I have crossed the plug wires before and it tries to start but won't. It happens to the best of us.
post #27 of 27 Old 04-12-2010, 09:06 PM Thread Starter
ARVENO
i have changed the wires one at time just be sure.....
I still have that "beeeep" sound from the gas tank....
so i give up,tomorrow i'll tow the jeep to the shop........
if it's something "mechanically" i can do it, but i cannot deal with "electronic stuff " i know my limits...LOL!!
ARVENO is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 05:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
will the stock fuel pump work with a TBI 350? Timmer YJ Wrangler Technical Forum 4 09-28-2007 01:07 AM
fuel pump won't work jeep795 YJ Wrangler Technical Forum 6 11-19-2006 11:57 PM
