maybe fuel pump does not work... - JeepForum.com
post #1 of 27 Old 04-12-2010, 09:30 AM Thread Starter
ARVENO
Hi guys , howdy!
My jeep is not working...the engine cranks but it does not fire up...
from the gas tank comes a "noise"like a "biiiip"...straight and keeps going... , i guess is the fuel pump.
usually "we" ear that "noise"for few seconds, when turning the keys,the fuel pump get in the pressure...
now that noise keeps going and going....
My questions are : could be the fuel pump ? does any one here experienced the same issue........??
thanks..
btw, today i went to work with the bus....
ARVENO is offline
post #2 of 27 Old 04-12-2010, 09:44 AM
Mark05059
you need to check for fuel pressure at the rail. There is a little valve under a metal cap. You can push it and check to see if fuel squirts out. Also when was the last time you filled up?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 27 Old 04-12-2010, 10:22 AM Thread Starter
ARVENO
Hi, the problem started after i filled the tank....at a NEW gas station by my workplace....
COULD BE A COINCIDENCE TOO....
I got home,and when i restarted the jeep to go out....the problem began...
I pulled the hose on the throttle body,and when tried to start the jeep,the fuel got out from that hose...and that noise was still going......and its right there from the gas tank....
The valve you said is under the gas tank cap ?
I have to take the tank off or would I be able to reach it with the tank on the jeep.....?
ARVENO is offline
post #4 of 27 Old 04-12-2010, 10:53 AM
MJMPC
You need to fill out your jeep info so we know what you have.......
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 27 Old 04-12-2010, 10:56 AM Thread Starter
ARVENO
1989 2.5l YJ
ARVENO is offline
post #6 of 27 Old 04-12-2010, 11:12 AM
EABiker
Try pouring a small amount of fuel down the throttle body and see if it starts; if it fires and then dies, that means you have spark but no fuel. If nothing, you have a spark issue. Since you can hear the pump, that means the control circuitry for it is good, and either you have a badly clogged fuel filter, or the pump needs to be replaced.
EABiker is offline
post #7 of 27 Old 04-12-2010, 11:17 AM Thread Starter
ARVENO
question : is the fuel arrive to the TB means that the fuel pump is working am i correct ?
..and why the "beeep" from the gas tank its keep going ?
thank !!
ARVENO is offline
post #8 of 27 Old 04-12-2010, 01:20 PM
RebuildRookie
is it more like a high/low pitched whine from the fuel pump? Have you checked for spark yet? You can try what EABiker says.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #9 of 27 Old 04-12-2010, 01:28 PM Thread Starter
ARVENO
Hi, now i am "working "....tonight the first thing i'll do is check if it got sparks...
I hope no....that would be easy to fix... take the gas tank off is a pain in the neck....
ARVENO is offline
post #10 of 27 Old 04-12-2010, 01:48 PM
RebuildRookie
I know!!! and please dont ask me how many times I know. haha
post #11 of 27 Old 04-12-2010, 01:48 PM
EABiker
thank !!
The "beeeeeeeeeeeeeeeeeeeeeee" from the fuel tank may be a pump with the impeller broken off, and the fuel in the line may just be residual from the last time it worked!
I'd start PB blaster treatment on the fuel tank strap bolts!
EABiker is offline
post #12 of 27 Old 04-12-2010, 02:18 PM Thread Starter
ARVENO
the gas tank in new.... changed it 3 month ago...
the fuel goes out only if i crank the motor....
"I've unscrewed the fuel line from the TB,than "cranked"the motor...and fuel went out from the fuel line....and stopped only when i cranked off the engine.....
ARVENO is offline
post #13 of 27 Old 04-12-2010, 03:08 PM
RebuildRookie
does it act like it wants to start (sputtering shaking motor) or is it just turning over and over.
Have you changed spark plugs recently, if so check your wires again to make sure. Ask me how I know.
Sounds like possibly bad, dirty, disconnected CPS?
post #14 of 27 Old 04-12-2010, 03:44 PM Thread Starter
ARVENO
Hi, yes, it want to start...and due that "Beeeppp" from the tank i thought something was wrong about the fuel sistem..
for sure,it missing fuel or sparks...
tonight i'll check spark plugs, distributor etc....
the spark plugs are old....
how do you know..??
ARVENO is offline
post #15 of 27 Old 04-12-2010, 04:05 PM Thread Starter
ARVENO
..BTW what type of plugs would you recommend ?
I was thinking something like bosch platinum 4003 or autolite AP 985 .
now i got champion RLY 12 ( if i remember well )
ARVENO is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 05:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
will the stock fuel pump work with a TBI 350? Timmer YJ Wrangler Technical Forum 4 09-28-2007 01:07 AM
fuel pump won't work jeep795 YJ Wrangler Technical Forum 6 11-19-2006 11:57 PM
