Maximum backspacing? - JeepForum.com
post #1 of 5 Old 04-29-2007, 08:13 PM Thread Starter
bayvilleYJ
Hey guys , im about to order up a new set of rims and tires . I was wondering if anyone knew what was the most backspacing i could run , as well as the narrowest rim. I'm tring to get some really skinny tires with lots of backspacing to bring them back inside the fenders. I'm gonna go with either 39.5 by 13.50 irocs , or 38.5 by 11 inch boggers , or maybe 38 by 12.50 tsl's , ( opinions welcome on this as well). I'm gonna go with 17 inch rims ,and they will be mounted on full width ford dana 44 and 60. Thanks in advance.
bayvilleYJ is offline
post #2 of 5 Old 04-29-2007, 08:59 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
what steering arms are you planning on running? that will make a difference.
stock h2 wheels pull the tires back in....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 5 Old 04-30-2007, 09:54 AM Thread Starter
bayvilleYJ
I dont have a highsteer arm , just a tie-rod in front of the axle , then another rod that comes up to the pitman arm , basically modified stock yj steering. Do the stock h2's come in 8 lug? I thought they were 6 , maybe those were h3's i saw? Any recomendations on tires as well ? Thanks a lot.
post #4 of 5 Old 04-30-2007, 10:41 AM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
for tires if your on technical trails w/ mud and rock. Super Swamper TSL's, but if its predominantly mud, go bogger, or go home.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #5 of 5 Old 04-30-2007, 07:57 PM Thread Starter
bayvilleYJ
I will be using it on lots of trails and mud , no rocks , and a decent amount of around town driving. I ran boggers before , but they were 35 by 14.50 , not the tall skinny ones im referring too. I think someone on the forum is running them? I'm pretty torn between the skinny boggers and the irocs.
What should the maximum throttle be? TheMatrix TJ Wrangler Technical Forum 3 08-21-2009 06:00 PM
maximum MML? tcox TJ Wrangler Technical Forum 26 02-24-2009 09:02 AM
How can I get the maximum Flex Inukshuk YJ Wrangler Technical Forum 11 10-21-2005 07:53 AM
Maximum Rubber VaNiLaIc3 YJ Wrangler Technical Forum 15 03-03-2003 06:01 PM
Maximum torque Hassan Choucri YJ Wrangler Technical Forum 5 01-03-2002 09:37 AM
