Max tire on 2.5l - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Max tire on 2.5l
Rough Country Lift Kits now available at Baseline 4x4 OutfHeavy Duty 2007-2013 Jeep JK Wrangler Perfmance Ball Joint1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 02-23-2011, 08:26 PM   #16
Schaef81
Fastest Ive ever gone in a YJ was 93 in a complete stocker I believe that will never happen to me again. With the 2.5L and 33s 4.88 is the correct gear ratio to return to factory power. 4.88s with 35s would be like 31s with 4.10s, to put things into perspective.
Schaef81 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2011, 08:30 PM   #17
baritone_mike
TheNewbie
Yes the difference is only 14.86% but for driving it is much easier to find 15% you just find 10% and then divid by 2 and add it to the 10%.
You were actually going closer to 103.5mph
baritone_mike is offline   Reply With Quote Quick reply to this message
Unread 02-23-2011, 08:32 PM   #18
TheNewbie
I find that hard to believe even though I was there. But it did feel like the paint was about to peel off.
It's funny how 150 in my Mustang felt like about 90 in the YJ.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
My build thread...
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 09:29 AM   #19
Wrangler11
Try can keep on track of what the thread was created for.
1991 Jeep Wrangler 4.0l auto
1995 Ford F350 Crew cab 7.5l
Previous Jeeps
2002 TJ, 1995 YJ, 2 1994 YJ, 1978 CJ7, 1970 CJ1, 2008 Grand Cherokee, 1997 Grand Cherokee, 1994 Cherokee, 1988 Comanchee
Wrangler11 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 09:44 AM   #20
Destr0
My four angry squirrels are still stock other than 3/4" shackle lift and 31s with tube fenders-
I can hold 80MPH easy on the highway (GPS verified speed, I believe speedo shows 72 or something), although this is in IN where we don't have too many real hills.
I am dropping in some s10 leaves for a bastard pack lift, an 8.8 with 4.56 gears and doing 4.56 gears in the front and bumping up to 35s. I am still looking for a set of 33s for daily driving and keeping the 35s for trail (I DD my YJ 40 miles each way to work).
I also have a 4.0 TB and spacer to drop in, an AX 15 (still need to find a Dakota bell housing) and a laundry list of other stuff to add. I collect parts faster than I can get them installed... mostly because I hate working in the cold and my garage is too full of parts to fit the Jeep inside at the moment (got a 4.0 on a stand and 4.2 hanging from the cherry picker, going to build a 4.5 stroker, although current thinking is to put that in my XJ).
I am OK with the power I get from the 2.5, although that may change once I go bigger than the 31s I am running now. On 31s it is just fine-not a rocket but who needs to go fast in a YJ?
Destr0 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 09:46 AM   #21
Unii
35's on mine with 4.88s, looking for 37's
Unii is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 10:56 AM   #22
xaran
Im running 4:88 gears with 32-11.5-15 tires and can pull 65 - 75 mph in 5th gear almost all the time on local freeways. I still try to stay away from 33" tires because I can still feel a difference over the 32" tires.
Xaran
1995 YJ, 2.5 l, 4:88 R&P
4" RC Lift, 1" BL, 32-11.5-15 tires
8000 lb HF Winch
xaran is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 06:33 PM   #23
AaronJ
My jeep is on 33's with the stock gearing and the 2.5.
Overdrive is useless.
On level ground 65mph can be held just fine in 4th without too much fuss but if you encounter a hill/overpass/headwind your speed is going to fall into the 50's.
It's all wind resistance. At speeds of 55mph and below my jeep scoots around and feels like it has plenty of power. That last 10mph makes all the difference.
Btw, the only way a stock-engined 2.5 YJ will do over 100mph is down a hill or off a cliff. In either case it isn't really helpful here.
AaronJ is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 07:42 PM   #24
wheelin
im running 31's and my 2.5 struggles to maintane 60mph on flat, which we have very little of in my part of the state. I usually pull over after i get about 4 or 5 cars behind me, and let them by.
wheelin is offline   Reply With Quote Quick reply to this message
Unread 11-12-2013, 10:42 PM   #25
soundline
My wife is running 31s with a 92 Wrangler 2.5. Like they said, 5th gear isn't worth the effort. 55 mph in 4th is comfortable to cruise with. Small lift and stock gears. No additional mods except a brute force intake. Mpg is prob 17 highway. Running on some of the WA State Mt passes it drops below 50 mph.
Yes I realize this is 2 years old, but the information is still relevant.
soundline is offline   Reply With Quote Quick reply to this message
Unread 11-12-2013, 11:03 PM   #26
Norcal_chris
Norcal_chris's Avatar
37s.
Drives to and from rubicon/fordyce/reno, etc
2.5/doubler,D60/14bff,108.5WB,H1s,39 Red label Krawlers ,17in beadlocks, 3link front w/ 14in Kings/4 link rear w/ 14in kings
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline   Reply With Quote Quick reply to this message
Unread 11-13-2013, 06:05 AM   #27
EABiker
Another stock geared 32" kinda guy here...I can run 70 on the highway in 5th, even up shallow grades, and obviously, perfectly fine around town. I moved up from 31's, and would never go back.
EABiker is offline   Reply With Quote Quick reply to this message
Unread 11-13-2013, 10:10 AM   #28
StanF
32s + 2.5L + AX5 + stock 4.10s = useless 5th gear and general poor highway performance.
Around town and offroad its fine.
My Ammo Can Console: http://www.jeepforum.com/forum/f12/yet-another-ammo-can-project-finished-1498520/
My 8.8 Swap: http://www.jeepforum.com/forum/f12/yet-another-ford-8-8-swap-extras-1565339/
StanF is offline   Reply With Quote Quick reply to this message
Unread 11-13-2013, 05:28 PM   #29
WidowYj91
I can run 90 with this setup on an old very worn out 2.5. My whole highway driving range is under 2700 rpm.
WidowYj91 is offline   Reply With Quote Quick reply to this message
Unread 11-13-2013, 06:16 PM   #30
Sparrows
I'm on 31x10.5s and have no problems. 75 on the freeway in 5th, easily hold 65 up steep grades in 4th gear.
Something is wrong with your rig then. I have 31s and can easily hit 80 still on the freeway. It may take me a bit longer than a 4.0 to get up to speed, but once there it holds it fine. I can make my 20 mile commute with hills in 5th the whole time at 70+...
Ditto. My 2.5 sits at around 2800-3000 rpms from 70-75mph.
Cheers
[URL="http://www.jeepforum.com/forum/f22/warbird-2-a-2242713/"][size=3][b]WARBIRD 2[/size][/b][/URL]
[URL="www.exiledoffroad.com"][size=2][b]EXILED OFFROAD[/size][/b][/URL]
[size=2][b]June '13 YJOTM[/size][/b]
Sparrows is offline   Reply With Quote Quick reply to this message
