Max tire on 2.5l - JeepForum.com
post #1 of 36 Old 02-23-2011, 08:04 PM Thread Starter
Wrangler11
Wrangler11's Avatar
Max tire on 2.5l
I picked up a 95 YJ 2.5l 5sp with 107,000 miles yesterday. This is my 7th jeep. I've never had a 2.5l before. I could not pass it up as the jeep was in perfect condition. It may need a new clutch or possibly scyncro a will see..
I had a 02 TJ with 34's and never had any problems with it on the trail. ARe 33's or 34's too much for a 2.4l? What do you guys recommend as far as tire size and the 2.5l?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #2 of 36 Old 02-23-2011, 08:06 PM
TheNewbie
I run 33's with the 2.5 and stock gearing. It's fine in town and great offroad, but it's a dog on the highway.
If you regear you can get away with larger tires. A lot of folks like to run 35's with the 2.5, but I set my limit at 33's with the stock gearing (4.10).
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 36 Old 02-23-2011, 08:07 PM
bft89yj
i run a 2.5 with 33s and its not bad at all off road but on road is a different story i cant use fifth at all but i can still do like 65 but im also running some engine mods and an inertia which made a huge difference off roaad
not so stock 89 yj on 35s
bft89yj is offline
post #4 of 36 Old 02-23-2011, 08:21 PM
MLJeeper
MLJeeper's Avatar
My 2.5 performs very well offroad on 35" tires. Decent onroad with a regear.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 36 Old 02-23-2011, 08:22 PM
TheNewbie
What did you regear to? And how does it do on the highway with the 35's and a regear?
post #6 of 36 Old 02-23-2011, 08:24 PM
04KJlimited
2004 KJ Liberty
4.88's and 35's max... anything bigger you can't gear low enough for
04KJlimited is offline
post #7 of 36 Old 02-23-2011, 08:26 PM
MLJeeper
MLJeeper's Avatar
I run 4.56s. Average 16 to 17 mpg with a 65 mph cruise speed. Will cruise 70 but mpg's go to crap. Do not use 5th except on flat ground and downhill, but it works. I agree with ok4, dont think i would tr and DD bigger than 35" tires with a 2.5.
MLJeeper is offline
post #8 of 36 Old 02-23-2011, 08:28 PM
TheNewbie
I run 4.56s. Average 16 to 17 mpg with a 65 mph cruise speed. Will cruise 70 but mpg got to crap.
That's better MPG than I'm getting on 33's and 4.10's.
Does it pull well up hills at highway speeds? And does a headwind kill your momentum like it does with 4.10's?
I'd like to swap gears someday, but I haven't decided between 4.56 or 4.88 gearing yet.
post #9 of 36 Old 02-23-2011, 08:31 PM
MLJeeper
MLJeeper's Avatar
Yeah head winds suck, but they suck for 4.0s too, its a box with wheels.. Otherwise it pulls ok. A 2.5 is never going to pull hard, LOL.I went with 4.56s because I already had a 9" ford geared to 4.56 for the rear. While there is not that much difference between the two ratios, with the 2.5 i would go as low as you can, aka 4.88.
MLJeeper is offline
post #10 of 36 Old 02-23-2011, 08:40 PM
wannafixmyjeep
33s is it. I ran them and then went to 30s because it was BAD on the highway(48 top speed) with the 30s it is more than tolerable. I want 31s now.
wannafixmyjeep is offline
post #11 of 36 Old 02-23-2011, 08:53 PM Thread Starter
Wrangler11
Wrangler11's Avatar
Wow I did not expect this much positive feed back. Looks like I have some things to think about. I'm not sure what to do.
post #12 of 36 Old 02-23-2011, 08:56 PM
Ripper3494
im runnin 33s in 4.88s, around town it feels not much different from my dads 4.0 on 31s with stock gears, but on the highway is where it shows bad, swapin an lt1 in the next few months tho so no more angry squirrels for me
Ripper3494 is offline
post #13 of 36 Old 02-23-2011, 09:01 PM
TheNewbie
WOW, something's not right if your top speed is 48. I've hit 88 on the highway before, but then I somehow ended up in 1985.
And when I was in the high 80's that was the uncorrected speed for those tires, so I was actually going faster than that. I wouldn't want to hold that speed for long in a lifted Jeep YJ though.
post #14 of 36 Old 02-23-2011, 09:03 PM
baritone_mike
I run 33's and have no problems I am still on stock gears (4.10) with the rest of my family in the Jeep (about 400 extra pounds) 35mph is in 3rd but with just me it is 4th. I can keep 50 just fine in 5th and have no problem going 60mph if you go uphill you might have to shift to 4th but I have never had to drop more than one gear and even then I still keep speed just fine. Just remember that your spedomiter will be off by 15% so when it says 30 you are doing 35 and when it says 51 you are doing 60.
baritone_mike is online now
post #15 of 36 Old 02-23-2011, 09:10 PM
TheNewbie
No way... So when my speedo said 88 I was going 101.2 MPH. I didn;t think a YJ could do that.
No wonder it felt like I was about to tear a hole through the space time continuum.
35" Tire + Rugged Ridge RRC Tire Carrier + Hi-Lift Jack Mount Joe2478 TJ Wrangler Technical Forum 2 08-20-2010 07:03 PM
35" Tire + Rugged Ridge RRC Tire Carrier + Hi-Lift Jack Mount Joe2478 JK Wrangler Technical Forum 1 08-20-2010 12:24 PM
31" Tire on stock tire mount rubber stop question? Diablosjeep TJ Wrangler Technical Forum 8 04-04-2008 09:02 PM
Moving tire jack to spare tire bracket? Whts everyone think about this item on Ebay? brewc TJ Wrangler Technical Forum 2 11-19-2004 08:08 AM
What is the biggest size tire the factory spare tire holder will hold? keys741 TJ Wrangler Technical Forum 13 08-03-2003 02:59 PM
