Max lift on YJ with no sye/cv modifications? - Page 4 - JeepForum.com
post #46 of 52 Old 11-12-2013, 05:39 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Originally Posted by Mambo_Dave
I'm posting in this thread because I don't like new threads for existing subjects. I'm contemplating buying a Rough Country 4" lift kit. My question, since I've not put eyes on a lot of them, is just how much can a transfer case be lowered? Do different kits lower them different amounts? (lower seems better) This seems to be part of why some people get vibes and some don't - the amount the transfer case was lowered.
The proper way to fix the vibrations is to get a slip yolk eliminator. Why would you lift the jeep just to lower the transfer case and reduce clearance? You can shim the rear axle to help fix vibrations too.
Tcase drops put stress on your motor mounts which can reduce the life span of them. If you're gonna drop the case, get a 1" motor mount lift from brown dog to help your tcase drop
Michaelgoesrawr is online now
post #47 of 52 Old 11-12-2013, 07:03 PM
superj
I have an old man emu 2.5" lift and a t-case drop and still have vibes. I need the sye and driveshaft
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #48 of 52 Old 11-13-2013, 10:15 AM
StanF
+1 for a motor mount lift instead of a Tcase drop.
Another reason for an SYE - I also worry about the slip joint pulling out of the transmission when offroading. You will reduce the engagement of the slip yolk splines when you install a suspension lift. Higher lifts = less engagement.
StanF is offline
post #49 of 52 Old 11-13-2013, 04:33 PM
Damon1995
i have 3.5" springs and 1.75" lift shackles and no sye.
Damon1995 is offline
post #50 of 52 Old 11-13-2013, 05:53 PM
superj
I bet having an automatic makes a difference on this. Auto 6 cylinders have the shortest driveshaft, I imagine
superj is offline
post #51 of 52 Old 11-13-2013, 05:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by crazyquadder View Post
...blah blah blah...
Almost forgot about this guy. Don't be this guy, kids.
Luck Favours The Prepared
Anticanman is offline
post #52 of 52 Old 11-13-2013, 06:50 PM
AmmitOsiris
AmmitOsiris's Avatar
Never be this guy.... He deserves a whack
Sent from Peggy's office
AmmitOsiris is offline
2" Suspension Lift Modifications? mossimo19 TJ Wrangler Technical Forum 7 06-21-2013 10:54 AM
modifications i will have to make after putting in a 2.5" suspension lift wrangler10 TJ Wrangler Technical Forum 28 10-19-2009 06:11 PM
Lift modifications jeepgeek2k TJ Wrangler Technical Forum 4 06-18-2008 05:20 AM
Lift Kits Require Drive Line Modifications? hifiguy7 JK Wrangler Technical Forum 2 07-29-2007 08:35 AM
Help me identify lift\body modifications (not dialup friendly) KyleS YJ Wrangler Technical Forum 2 01-06-2006 04:48 PM
