Max lift on YJ with no sye/cv modifications? - Page 2 - JeepForum.com
post #16 of 52 Old 03-02-2009, 06:55 AM
dodger889
Most of the time depends on how well the drive shafts are balanced. You have to remember they mass produce the drive shafts for the OME. They used a very wide tolerance. Them know most people where not looking for the smoothest ride in a jeep. If you find the you have drive shaft vibes and after you have checked the rest of the driveline out for bad u joints or a bad yoke ( rusted or bent ) or play on the slip joint. Then tak the drive shaft in and have it checked balance.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #17 of 52 Old 06-05-2009, 08:36 AM
green89yj
Will vibes do any damage to the vehicle and driveline if they aren't like to the point of shaking the whole vehicle? What would be the long term effects of driving around with driveline vibes aggravated by a 4" or so lift? I realize that every vehicle will be different but just an average amount of vibration over a 10 year time frame or whatever, what damage is gonna result from that?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #18 of 52 Old 06-05-2009, 01:36 PM
Exparrot
Exparrot's Avatar
U-joints would probably be the first thing to go.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #19 of 52 Old 06-05-2009, 02:19 PM
shinerm02
I installed a RC 2.5" lift and had this with my DS....
I know it will settle but I did not want to chance it so I bought a JB conversion SYE and an XJ front DS from the local pick and pull. A shop near me will cut and balance it for $60. So long story short...
SYE $217.00 delivered
xj DS $25.00
Cut and balanced $60.00
For $302.00 I won't have to try MML or TC drop and see IF they work. Once I get my rear pinion angle correct it will work.
shinerm02 is offline
post #20 of 52 Old 06-05-2009, 02:22 PM
Louie4
That is a haggard looking driveshaft angle. And its from a 2.5" suspension lift? Crazy.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #21 of 52 Old 06-05-2009, 02:56 PM
green89yj
That's what I figured. Thanks.
So when you install a SYE where is the play in the driveshaft? Would you then have no slip at all between your pinion and transfer case? Is that ok? Is there still a slip joint on the pinion/differential end?
post #22 of 52 Old 06-05-2009, 03:08 PM
shinerm02
Here is a pic of the XJ DS. It has not been shortened yet.
The slip is in the middle of the DS.
post #23 of 52 Old 06-05-2009, 09:04 PM
h2osprt
I have a 4" lift and 33's with no vibes. That said I'm planning on an SYE soon
h2osprt is offline
post #24 of 52 Old 06-05-2009, 09:47 PM
green89yj
I have an XJ shaft all ready to shorten but I was just thinkin that when you shorten it, you're gonna lose your slip. Do you just cut it down at the CV end? I think I get it now.
post #25 of 52 Old 06-05-2009, 09:56 PM
yjjustforme
Check my mods im too lazy to type it out. but mine has run great with little to no vibes since i lifted it 4.5" 5 years ago
Just let me get my hands on the guys that decided to install torx bolts on JEEPS!
yjjustforme is offline
post #26 of 52 Old 06-05-2009, 09:59 PM
green89yj
Is that with a transfer case drop or what? No SYE or CV right? I didn't see any of that in your specs but just wanted to make sure.
post #27 of 52 Old 06-06-2009, 04:26 AM
yjjustforme
yeah i got a t case drop with no sye and cv.
post #28 of 52 Old 06-06-2009, 09:03 AM
green89yj
alright. Gotcha. I'm gonna have to check you profile for a pic with the drop. thanks.
post #29 of 52 Old 10-18-2009, 11:30 PM
geo1400
Sorry digging this one out the archive...
I've just done a 2.5" RC lift with no TC drop - Vibs make it almost undrivable! Going to do a TC drop but just want to confirm; is a TC drop a temp fix for a 2.5" lift? I read in another thread that it should only be done untill you install the SYE.
If that's the case I might just do the SYE and be done with it... don't have the $$ at the mo tho!
Did you hear about the ice-cream man who was found dead covered in hundreds and thousands?
He topped himself...
geo1400 is offline
post #30 of 52 Old 10-19-2009, 06:10 AM
coachholland
Dropping the TC should go a ways in correcting the driveline angle. It may be that will be all you'll need to do without the expense of a SYE.
'95 YJ 4.0 5-Speed with a mod or two...
coachholland is offline
2" Suspension Lift Modifications? mossimo19 TJ Wrangler Technical Forum 7 06-21-2013 10:54 AM
modifications i will have to make after putting in a 2.5" suspension lift wrangler10 TJ Wrangler Technical Forum 28 10-19-2009 06:11 PM
Lift modifications jeepgeek2k TJ Wrangler Technical Forum 4 06-18-2008 05:20 AM
Lift Kits Require Drive Line Modifications? hifiguy7 JK Wrangler Technical Forum 2 07-29-2007 08:35 AM
Help me identify lift\body modifications (not dialup friendly) KyleS YJ Wrangler Technical Forum 2 01-06-2006 04:48 PM
