Mating Issues with 95-2.5L to 93 Automatic - JeepForum.com
post #1 of 7 Old 06-20-2010, 09:58 PM Thread Starter
bigredjeep95
Having a few problems lining up trans to engine. '95 YJ Jeep with a 2.5L had and automatic, still using the '95 Flywheel . Trans is a 93 YJ automatic for the 4cyl using the 93 torque converter. ive tried putting them together four times and i can get it tight on top but can't the bottom to come tight. Is there some kind of fitment issue i dont know about? Do i need the '93 flywheel? Or use the 95 t converter?
95 YJ Wrangler - 35" Swamper SSR's, 4.5" Rubicon Express Lift Spring with Spring Over, 4.10 Gears, Ford Dana 44, Ford 9", M8000 Winch
1995 YJ Wrangler- 2.5, 2" Lift 31" Tires
1975 Cherokee S Widetrack, 6" Lift, 35" Baja Claws, AMC 360
2012 Chevy 2500HD 4x4 6.0
2002 WJ Grand Cherokee Limited, AFE Intake,DD
1990 YJ Wrangler - Torn Apart
bigredjeep95 is offline
post #2 of 7 Old 06-20-2010, 10:02 PM
MJMPC
Are the ears on the torque converter seating in the pump?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 7 Old 06-20-2010, 10:04 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
It sounds as though the torque convertor isn't fully seated into the front pump of the automatic tranny. You must remove the transmission & make sure this is done properly.
Failure to seat the torque convertor will result in the torque convertor shattering the front pump in the tranny.
Note the notches on the torque converter shaft.
Note "ears" on the inside of the hole in the pump gear. Those must engage, otherwise the tranny won't seat all the way to the engine. If you force it on, it will break the pump.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 7 Old 06-20-2010, 10:05 PM Thread Starter
bigredjeep95
im pretty sure i had the converter in all the way, i kept spinning it and pushing in and it wouldn't go in any farther. i'll have to drop tomorrow and double check that.
post #5 of 7 Old 06-20-2010, 10:13 PM
MoparFreak69
Sometimes they really fight you to go in all the way. What I do is place a finger under the nub that sticks out of the center and lift up slightly and press in towards the transmission. I spin the converter fairly quickly with my other hand and wiggle my finger up and down moving the converter slightly. It takes a bit but it will suddenly slide all the way in with a solid thump. When looking across the face of the bellhousing (where it bolts to the engine) you should see no part of the torque converter sticking past the bellhousing. If there is anything seen past the bellhousing, its not seated fully and will give you problems installing like you are experiencing now.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #6 of 7 Old 06-21-2010, 01:20 PM
dodger889
You are installing the T/C in the trans before you try to install the trans to the engine?
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #7 of 7 Old 06-21-2010, 08:24 PM Thread Starter
bigredjeep95
OK , dropped the trans today, had to spin the TC pretty good and lift and push, and the TC went in another inch or so. Everything went together pretty good after that. Thanks for the help guys.
Acceleration or shifting issues in automatic harleytroubl JK Wrangler Technical Forum 0 04-30-2009 12:53 PM
1993 4.0 Automatic Starting Issues Zavaslacker YJ Wrangler Technical Forum 1 02-07-2009 07:57 PM
Automatic trans. shifting issues oleman55 TJ Wrangler Technical Forum 0 09-13-2008 06:46 PM
automatic tranny issues 86cherokeexj799 TJ Wrangler Technical Forum 4 10-26-2006 11:53 AM
Any issues with 1" Bodylift and automatic? condoor YJ Wrangler Technical Forum 1 09-28-2004 05:11 PM
