Master slave ?'s - JeepForum.com
post #1 of 6 Old 01-20-2010, 07:36 PM Thread Starter
Glamngrit
Master slave ?'s
When i put the new master slave on how do you bleed it i am trying to save my self from to the repair shop any advice or know of any sites that can help would be GREATLY appreciated
Glamngrit is offline
post #2 of 6 Old 01-20-2010, 07:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I think you mean the "master" was replaced?
The "slave" on your '92 is inside the transmission bellhousing.
Same as brakes mostly, have an assistant pump the clutch completely 2-3 times & then hold it down to the floor while you open & close the bleeder at the transmission bellhousing. Repeat this cycle twice, refill the reservoir with fluid & then start over with the pump/hold/open/close cycle for 2 more times before refilling the fluid again.
You may need to do it a LOT.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 01-21-2010, 11:49 AM Thread Starter
Glamngrit
thanks for the help
post #4 of 6 Old 01-21-2010, 03:29 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by Glamngrit View Post
thanks for the help
Have you been able to work on it yet?
Max
Mean Max is offline
post #5 of 6 Old 01-21-2010, 10:36 PM Thread Starter
Glamngrit
yes did it today and is works great thanks soo much!!
post #6 of 6 Old 01-21-2010, 11:00 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You're quite welcome. I'm glad you got it all sorted out.
Max
Mean Max is offline
master or slave? TJstyle97 YJ Wrangler Technical Forum 3 06-11-2009 12:46 AM
master slave cyl. to slave clutch hose gfortier YJ Wrangler Technical Forum 0 09-16-2008 08:37 AM
Master or Slave? jeepfury YJ Wrangler Technical Forum 9 04-19-2007 03:00 PM
slave/master 0IIIIII0 TJ Wrangler Technical Forum 1 06-30-2004 01:21 AM
Master and Slave bamakrw YJ Wrangler Technical Forum 20 02-13-2004 09:27 AM
