Master cylinder vacuum line? - JeepForum.com
post #1 of 9 Old 04-21-2013, 07:33 AM Thread Starter
Tarpo
My Jeep has been running great lately. But yesterday after driving it, I sat at idle then it died. I could not restart. After flooding trying to restart I let it sit for a while and started looking around.
It seems the vacuum line to the master cylinder fell off. Problem is, it's gone totally. Where does that vacuum line run? And can that be causing my no start?
88 yj. 95 4.0 4 Brl carb, Msd ignition, offenhouser intake, headers. Ford 8.8 rear end, sun fire seats. About to install a newer ax 15 to replace my tired ba10.
Tarpo is offline
post #2 of 9 Old 04-21-2013, 08:20 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
You mean the vacuum line to the brake booster?
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is online now
post #3 of 9 Old 04-21-2013, 08:29 AM Thread Starter
Tarpo
Sorry, this is the line I mean. I found the line, but isn't there supposed to be a cap on the end of it?
Tarpo is offline
post #4 of 9 Old 04-21-2013, 08:43 AM
jokerchief462
No cap hooks from brake booster directly to the intake manifold. And yes that will cause your hard start.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 9 Old 04-21-2013, 10:00 AM
4.7stroker
Once you do get it started you wil find you can't stop.
Dwyne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #6 of 9 Old 04-21-2013, 10:26 AM Thread Starter
Tarpo
I still can't get it to start. I've got a buddy coming by tomorrow with a timing light. I'm getting backfires, and it sounds out of time. I'm not sure how old the cap and rotor are.
I may go ahead and replace the cap, rotor, plugs and wires. My plugs are fouled bad. Very black, and soot covered. And it looks like the gaps are about twice the distance they should be.
Tarpo is offline
post #7 of 9 Old 04-21-2013, 10:51 AM Thread Starter
Tarpo
Can anyone ID this distributer?
Tarpo is offline
post #8 of 9 Old 04-21-2013, 12:49 PM
4.7stroker
Looks like a HEI to me.
[url]
[url]
post #9 of 9 Old 04-22-2013, 10:01 AM
Flajeeper1
1987 YJ Wrangler
Replace the vacuum line first, when the vacuum leak is fixed only then can you look at other issues. And yes that's an HEI distributor, you may already have a nuttered ignition system.
Flajeeper1 is offline
