Master cylinder upgrade? - JeepForum.com
post #1 of 28 Old 07-05-2013, 08:52 AM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
My master cyl on the YJ is leaking so I figured if I was going to replace it why not upgrade. For example if going tons the upgrade is a 1 ton mc. It's got a factory 30 and 8.8 disc brake rear, 35s and a FI 302.
Anyway does a TJ MC fit on a YJ? Anyone done the swap? The reason I ask is I have one off of my TJ that isn't being used since I'm swapping a dodge MC
Thanks
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 28 Old 07-05-2013, 09:23 AM
jokerchief462
I am looking for the same when I put an 8.8 in. I have read a 95 booster and MC and a MC from Ford E350.
Have to pay attention to which side the lines hook up to MC.
In my case attachment to peddle addy may need some rework also.
Most of the brake upgrades are well documented in the 8.8 install threads.
I am leaning toward the 95 setup and buried in that thread was a proportion inch valve from IIRC an XJ.
So I am still researching just picked up an 8.8 yesterday needs a regear. Install and the the brakes.
I have a 4" lift on 33s SUA and since the mods the brakes are acceptable but could be so much better.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 28 Old 07-05-2013, 11:28 AM Thread Starter
JeepRocks86
The reason I ask is because my YJ is ba and I have a factory TJ one on the shelf at home not brig used.
For Sale:
post #4 of 28 Old 07-05-2013, 01:24 PM
jokerchief462
If it fits give it a try and see what you get.
post #5 of 28 Old 07-05-2013, 02:55 PM
DLWRUBI
If your 95 YJ had a 4.0L in it then it already had the better MC (dual diaphragm) over previous years, not sure a TJ MC will buy you much. An upgrade would benefit if you had bigger calipers over stock and a properly sized MC. Since you already have a TJ one, not sure if it will work, but would be worth a shot and then you can tell us ..
DLWRUBI is offline
post #6 of 28 Old 07-05-2013, 03:17 PM Thread Starter
JeepRocks86
It was a 4cyl originally. 2 chamber metal reservoir as opposed to plastic on the TJ. I figure I will give it a try.
For Sale:
post #7 of 28 Old 07-05-2013, 03:32 PM
rambo3489
Get one off of a mid 80's e350 van. Got my reman for $20. 1.25" bore. Gets the job done.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #8 of 28 Old 07-05-2013, 03:36 PM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
I used a dodge 2500 mc... Worked good stopping 40s. Google the swap, plenty have done it.
1948 CJ2a
Airborne4X4 is offline
post #9 of 28 Old 07-05-2013, 05:58 PM Thread Starter
JeepRocks86
Yep the 2500 is a good swap when going to tons, but when staying with 30/8.8 I don't need that much
For Sale:
post #10 of 28 Old 07-05-2013, 06:53 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
The TJ booster/master swap is pretty easy, but not direct bolt up. You have to cut the plunger and extend it and drill the hole in the plunger rod a little larger. There are some write ups on it. I have done it and it's AWESOME! I can lock up my 33s.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is online now
post #11 of 28 Old 07-05-2013, 07:32 PM
Mywrangler94
You can use any master off of an XJ, but of course you have to shorten the rod....I have an extra who wants it? You pay shipping....leave me a pm with a number to call you ....
Mywrangler94 is offline
post #12 of 28 Old 07-20-2013, 07:32 PM Thread Starter
JeepRocks86
TJ mc won't fit YJ
Bummer
For Sale:
post #13 of 28 Old 07-20-2013, 07:56 PM
TSEJEEPERS
Originally Posted by JeepRocks86 View Post
TJ mc won't fit YJ
Bummer
It will if you swap the TJ booster too.
You must not have the 95 duel diaphram booster.
You could go with a 78 Mercury Grand Marquis with 4 wheel disc brakes, master.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #14 of 28 Old 07-20-2013, 08:09 PM Thread Starter
JeepRocks86
Just did a little more research. YJ was originally a 4cyl. Apparently the 4 and 6 cyls have a different booster and mc. Since my TJ is a long term project I will pull the booster off tomorrow and modify it to work.
For Sale:
post #15 of 28 Old 07-20-2013, 08:12 PM Thread Starter
JeepRocks86
Are the proportioning valves from a TJ an upgrade? Any benefit?
For Sale:
