-   -   Master cylinder upgrade? (http://www.jeepforum.com/forum/f12/master-cylinder-upgrade-1545198/)
JeepRocks86 07-05-2013 09:52 AM
My master cyl on the YJ is leaking so I figured if I was going to replace it why not upgrade. For example if going tons the upgrade is a 1 ton mc. It's got a factory 30 and 8.8 disc brake rear, 35s and a FI 302.
Anyway does a TJ MC fit on a YJ? Anyone done the swap? The reason I ask is I have one off of my TJ that isn't being used since I'm swapping a dodge MC
Thanks
jokerchief462 07-05-2013 10:23 AM
I am looking for the same when I put an 8.8 in. I have read a 95 booster and MC and a MC from Ford E350.
Have to pay attention to which side the lines hook up to MC.
In my case attachment to peddle addy may need some rework also.
Most of the brake upgrades are well documented in the 8.8 install threads.
I am leaning toward the 95 setup and buried in that thread was a proportion inch valve from IIRC an XJ.
So I am still researching just picked up an 8.8 yesterday needs a regear. Install and the the brakes.
I have a 4" lift on 33s SUA and since the mods the brakes are acceptable but could be so much better.
JeepRocks86 07-05-2013 12:28 PM
The reason I ask is because my YJ is ba and I have a factory TJ one on the shelf at home not brig used.
jokerchief462 07-05-2013 02:24 PM
If it fits give it a try and see what you get.
DLWRUBI 07-05-2013 03:55 PM
If your 95 YJ had a 4.0L in it then it already had the better MC (dual diaphragm) over previous years, not sure a TJ MC will buy you much. An upgrade would benefit if you had bigger calipers over stock and a properly sized MC. Since you already have a TJ one, not sure if it will work, but would be worth a shot and then you can tell us :)..
JeepRocks86 07-05-2013 04:17 PM
It was a 4cyl originally. 2 chamber metal reservoir as opposed to plastic on the TJ. I figure I will give it a try.
rambo3489 07-05-2013 04:32 PM
Get one off of a mid 80's e350 van. Got my reman for $20. 1.25" bore. Gets the job done.
Airborne4X4 07-05-2013 04:36 PM
I used a dodge 2500 mc... Worked good stopping 40s. Google the swap, plenty have done it.
JeepRocks86 07-05-2013 06:58 PM
Yep the 2500 is a good swap when going to tons, but when staying with 30/8.8 I don't need that much
87TPIYJ 07-05-2013 07:53 PM
The TJ booster/master swap is pretty easy, but not direct bolt up. You have to cut the plunger and extend it and drill the hole in the plunger rod a little larger. There are some write ups on it. I have done it and it's AWESOME! I can lock up my 33s.
Mywrangler94 07-05-2013 08:32 PM
You can use any master off of an XJ, but of course you have to shorten the rod....I have an extra who wants it? You pay shipping....leave me a pm with a number to call you ....
JeepRocks86 07-20-2013 08:32 PM
TJ mc won't fit YJ
Bummer
http://i78.photobucket.com/albums/j9...20F12623DE.jpg
TSEJEEPERS 07-20-2013 08:56 PM
Originally Posted by JeepRocks86 (Post 15699737)
It will if you swap the TJ booster too.
You must not have the 95 duel diaphram booster.
You could go with a 78 Mercury Grand Marquis with 4 wheel disc brakes, master.
JeepRocks86 07-20-2013 09:09 PM
Just did a little more research. YJ was originally a 4cyl. Apparently the 4 and 6 cyls have a different booster and mc. Since my TJ is a long term project I will pull the booster off tomorrow and modify it to work.
JeepRocks86 07-20-2013 09:12 PM
Are the proportioning valves from a TJ an upgrade? Any benefit?
The time now is 05:16 PM.
