Master Cylinder Bleeder--Location??? - JeepForum.com
post #1 of 1 Old 03-28-2010, 11:24 AM Thread Starter
1995Moneypit
Where is the bleeder screw for the master cylinder on a 1995 yj 2.5? Is this located at the front of the metal brake line "manifold" located directly under the MC?
1995Moneypit is offline
slave cylinder bleeder screw problems!!!! grimjeeperyj14 YJ Wrangler Technical Forum 2 03-21-2010 07:16 PM
Slave Cylinder woes...Missing Bleeder Valve Screw xjcrwlr YJ Wrangler Technical Forum 7 01-01-2010 06:43 PM
TJ slave cylinder bleeder install soxfanjp TJ Wrangler Technical Forum 2 09-29-2008 02:45 PM
Slave cylinder bleeder screw wesley75 YJ Wrangler Technical Forum 1 07-22-2008 05:44 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 09:37 AM
