Quantcast Marvel Mystery Oil vs. Rislone for hydraulic lifter ticking. - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Marvel Mystery Oil vs. Rislone for hydraulic lifter ticking.
Old 11-17-2008, 10:34 PM   #31
Mean Max
Mean Max's Avatar
Originally Posted by jgillespie88 View Post
alright, thanks pal!
No sweat! Let me know how it works out fer ya!
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 11-18-2008, 11:44 AM   #32
benjamin.olejnik
Anyone know what the Mobile 1 equivalent to a PH8A is? I guess I can go to the parts store and look up what Mobile 1 filter a 1994 F150 runs b/c that also ran the PH8A, but I tend to spend to much money in those places.....
benjamin.olejnik is offline   Reply With Quote
Old 11-18-2008, 12:59 PM   #33
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
After reading up on this i wouldn't run it more than 5 hours of running time in my oil. i would run it in my gas at 8-12 oz per 10 gallons.
when put in the oil it tends to;
dilute the oil.
effects the motor oils ability to hold dirt in suspension.
effects the dispersing ability.
lowers the viscosity level of the motor oil, which makes it less resistant to temp changes.
In the oil for a short time is helpful in loosening carbon deposits around the rings and sticky tappets which help the ticking noise.
in the gas it loosens carbon build up in the combustion chamber, on the valve stems(which can aid in the ticking noise) and carbon on the rings.
It leaves behind a lubricating film which adds life to the engine
its made from 3w oil, 20% solvent,dye,wintergreen(for smell) 779 ppm of a phosphorous additive and maybe more things
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote
Old 11-18-2008, 03:10 PM   #34
CheapSunglasses
2007 XK Commander
Originally Posted by firefighterjeep View Post
My 95 yj is suffering from the dreaded Jeep tick. I've read several threads on the subject and have found suggestions for using both products but haven't read anything comparing the two. Is one superior over the other?
Drain a Qt. of oil out and add a bottle of Lucas....If you want to take it a step further, pull the valve cover and clean all the rockers and pushrods....Make sure you can blow through all the pushrods....I even taped a q-tip to one of the pushrods, dipped it in kerosene and reached down to the lifter tops and cleaned the gunk off....My tick went away.
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline   Reply With Quote
Old 11-21-2008, 01:15 PM   #35
notmyj
Part of the Three Percent
notmyj's Avatar
Personally, i would avoid lucas like the plague. http://bobistheoilguy.com/images/lucas/lucas.htm
www.pghoffroad.com
My SOA Build
Recovery Gear Basics
My BUDGET York OBA Install
Budget Welding Cart
Carling Contura Switch Panel
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone installs a S35 kit or otherwise "upgrades" a D35, an angel looses its wings."
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x8, 35's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline   Reply With Quote
Old 11-21-2008, 05:16 PM   #36
benjamin.olejnik
My only issue with that whole experiment is there is no heat...
Old 01-12-2009, 09:37 PM   #37
blacky_j
Originally Posted by Mean Max View Post
I would try spinning the oil filter off & replacing it with the larger filter (PH8A or comparable) and topping up your oil with the MMO.
can you take off the oil filter without having to drain the oil?
i'm thinking about doing the MMO additive, but should i do it on a fresh oil change? ie: 5 quarts of oil, 1 quart of MMO?
or should i add it to the oil when its got 500 or so miles left before i need it to be changed?
[IIIIII]
blacky_j is offline   Reply With Quote
Old 01-12-2009, 10:42 PM   #38
hevybluzer
From experience..........Rislone, when used on a high mileage motor, can bring down a world of hurt over the long run. One time use to "free up'" a noisy lifter may be ok, but be careful.......Any sludge accessible to the rislone gets softened, displaced, and travels to the lowest point in the motor...the oil pan. On the 4.0, the relationship of the drain plug/pan bottom/oil pump pickup is such that even frequent oil changes will not remove the sediment once it gets there, which can eventually clog the oil pump pickup screen. Be very aware of your oil pressure after using rislone. If it starts acting strange (bouncing needle, low at idle, etc,,) you should drop the oil pan and check for a clog.
Using MMO will probaly do the same thing.
hevybluzer is offline   Reply With Quote
Old 01-13-2009, 12:40 AM   #39
blacky_j
can you change the oil filter without having to dump all the oil?
[IIIIII]
Old 01-13-2009, 02:31 AM   #40
Solus
no not unless you feel like getting dirty. Oil will spill out of the hole. You need to drain the oil before you change the filter.
Solus is offline   Reply With Quote
Old 01-13-2009, 03:21 AM   #41
xxxflhrci
You can change the filter without draining the oil. No more oil will spill out of the filter than if you had drained the pan. The filter is on the side of the block. The oil is in the pan.
xxxflhrci is offline   Reply With Quote
Old 01-13-2009, 05:17 AM   #42
Solus
^^ your right i wasn't thinking. Long as the jeep has sat nothing will come out but whats in the filter and such.
Glock Forum
