map sensor - Page 4 - JeepForum.com
post #46 of 46 Old 11-05-2012, 08:52 AM
Que89YJ
ZTE. Now that you were able to get the connector off the ecu, there are 2 sides to that connector. The pins that make contact inside On the back of the connector there is a shell. You need to pull the shell off and look at the back of the pins to see if any of the pins are pushing back when you connect the ecu. Check all the pins to make sure they are not "spread and not making good contact with the pins on the ecu. It looks like the ecu was forced and you should never need to force it and bend pins. Also look for any moisture inside of the shell.
Que89YJ is online now
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 04:22 AM
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 04:07 PM
My 2.5 takes a while to start, is it the cam sensor or crank sensor!! Divebum TJ Wrangler Technical Forum 9 12-24-2008 12:38 PM
power steering sensor needed? O2 sensor? Zorm YJ Wrangler Technical Forum 8 01-17-2008 08:06 AM
P0135; 02 Sensor Heater Malfunction, Sensor bad???? perley03 TJ Wrangler Technical Forum 5 01-18-2007 08:40 PM
