many tech ?'s - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > many tech ?'s
Memorial Day Weekend Sale Starts Friday-Tuesday 10% off + New DEAL OF THE WEEK at ROCKRIDGE 4WD!Deep discounts on Jeep Posi lok kits
Unread 10-23-2009, 12:59 PM   #1
satchmoe
many tech ?'s
what is the difference in a high pinion dana 60/44/30 and a regular 60/44/30?
does ox locker make a locker for the dana 60?
would a swap of a tbi engine be a good route to go considering the style of injection?
would appreciate advice on coming up with the ultimate yj build and following through with it over the next few years.
Stop me at any point-350/454tbi,transmission?, would an atlas 2 tc work with this setup?, dana 60's f & r, coilover conversion(4 link rear) or maybe i should read some more before creating a wish list.
any knowledge would help-sure everyone has found them selves at some point dreaming big!!!!!! Thank you all for your time
satchmoe is offline   Reply With Quote
Unread 10-23-2009, 01:13 PM   #2
texas_yj
Senior Redneck Member
texas_yj's Avatar
the high pinion axles have the pinion centerline above the ring gear center center line, so the driveshafts will be higher up on the pumpkin which will help with the drive shaft/u-joint angles. I wouldn't do an engine swap that wasn't injected, multi port is better then TBI but harder to do but bother better than a carb. fill out your profile for us, so we know what your starting with and we can possible help better
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline   Reply With Quote
Unread 10-23-2009, 06:20 PM   #3
timatoe
Originally Posted by satchmoe View Post
....... or maybe i should read some more before creating a wish list........
Yep, that's the one right there.
That's not meant to be rude or anything, but if you're asking the difference between high and low pinion axles, you need a lot more general knowledge before deciding on the "ultimate build".
timatoe is offline   Reply With Quote
Unread 10-23-2009, 06:46 PM   #4
czjeeper
I am a huge fan of EFI...especially for the trails.
I just converted my Plymouth 360 over using the Edelbrock Pro Flo EFI kit.
US Army combat vet
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area?
Check 'em out! Piston's Wild Motorsports Club
Click here for 2.5L AX5 to AX15 swap
czjeeper is offline   Reply With Quote
