manual transmission life and driveshaft play?? - JeepForum.com
post #1 of 6 Old 10-11-2001, 01:48 AM Thread Starter
evilpsych
evilpsych's Avatar
hey guys.. got a '93 wrangler w/ 109k miles on it.. shifting's a bit rough between 1st and second.. was wondering how long you guys clutches were lasting.. i've got the 6cyl.. also.. noticed a bit of play in the driveshaft.. heavy thunk when going between 1st and reverse.. guessing it's either worn ring and pinion, clutch, or maybe tranny.. dunno about the transfer case.. any clues?
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 6 Old 10-11-2001, 09:35 AM
Willis91YJ
Hey bud
Did you check the driveline u-joints (assessing the clunk not the clutch problems) On the clutch life I don't know, my bro owned my yj before me and he drives horribly and replaced the clutch before he sold it to me! Good luck
Willis
Oh by the way that u-joint is easy to replace if that is the issue!
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline
post #3 of 6 Old 10-11-2001, 11:38 AM
Kev
Master of the Obvious
Kev's Avatar
If you are having troubles shifting only from 1st to 2nd it is probably in the transmission. Mine does the same thing (half the time I just skip 2nd and go 1st to 3rd) and I've been told it is likely the syncros in the tranny.
FYI I got over 150,000 miles out of the clutch on my Chev 4x4 (but I sold it and bought my Jeep ).
I agree with Willis91YJ, I would check the u-joints on the driveline first. If the pins in the u-joint either rust or get destroyed it can create slop in the driveline.
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #4 of 6 Old 10-11-2001, 11:45 AM
powjunkie
My 1st clutch job was around 85-90K miles. If you haven't done yours yet, it's probably ready to go. Especially if you're running big tires without a gear swap (like I was for awhile). Definately check out the u-joints like Willis said. I've found that when you go from 1st to reverse with a good amount of force in each direction, you can tell if a u-joint is bad.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #5 of 6 Old 10-11-2001, 01:18 PM
I-4
I-4's Avatar
u-joints are cheaper than tranny work(and easier if you do it yourself!)i would check your u-joints first.hth
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #6 of 6 Old 10-11-2001, 09:08 PM
Nightclaw
The AX-15 isn't exactly known for it's smooth, refined shifting action... LOL! The 1-2 synchro, from what I have been told, is a frequent point of failure in the AX-15. Nothing double-clutching can's solve though.
Regarding clutch life, I just had mine replaced at 90k miles. It had plenty of material left, but the flywheel was glazed pretty badly (causing clutch chatter).
The thunk between first and reverse is present on my rig also. My U-Joints seem to be in good order, so I imagine it's just play in the diff and tranny. There will be play in any driveline, frankly (even my '99 Camaro "thunks" going into first gear while stopped).
Nightclaw is offline
How much play in driveshaft? Nickb1907 TJ Wrangler Technical Forum 16 01-09-2012 08:14 AM
CV driveshaft ujoint life bigriver YJ Wrangler Technical Forum 16 10-14-2009 04:14 PM
Dana 30 driveshaft play... iamadam1122 TJ Wrangler Technical Forum 5 08-10-2009 12:26 PM
Play in the driveshaft? KoKid28 TJ Wrangler Technical Forum 11 11-03-2008 06:36 PM
Play on the driveshaft... ((~JEEP~)) TJ Wrangler Technical Forum 8 08-21-2006 02:32 PM
