Manual transmission fluid - JeepForum.com
post #1 of 17 Old 03-07-2014, 05:54 AM Thread Starter
scbasspro
91 YJ standard 5 speed manual transmission. Qustion: What transmssion fluid to use when changing?
scbasspro is offline
post #2 of 17 Old 03-07-2014, 06:58 AM
djwrangler
1997 XJ Cherokee
Mobil 1 10w30 in my ax15
djwrangler is offline
post #3 of 17 Old 03-07-2014, 07:17 AM
mrdeath2000
gallon jug of walmart 10w30 ~$11
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #4 of 17 Old 03-07-2014, 08:03 AM Thread Starter
scbasspro
fill plug location on manual transmission
Where is fill plug located on manual transmission
post #5 of 17 Old 03-07-2014, 08:11 AM
mrdeath2000
on the ax-5 (2.5L manual trans) it's on the passenger side just above the thing that sticks out with a couple wires coming out of it. Plug head size is same as the drain on the very bottom just in front of the skid plate.
post #6 of 17 Old 03-07-2014, 09:16 AM
pat_v18
I personally would not run motor oil in a transmission. I know guys do it but the reality is, is that motor oil belongs in a motor, gear oil belongs in things with gears. I run synchromesh in my transmission. I got it at a local auto parts store for $6 a quart. And for changing your gear lube, you don't wanna do it too often. The longer you have the lube in, the better.
pat_v18 is offline
post #7 of 17 Old 03-07-2014, 09:51 AM
djwrangler
1997 XJ Cherokee
10w30 motor oil is the recommended fluid for the transmission. Straight from Jeep.
post #8 of 17 Old 03-07-2014, 10:33 AM
Old4X
1990 CJ7
Run whatever you want in your Jeep, but the factory long ago switched from gear oil to plain 10W-30 MOTOR oil as the recommended lube.
You best be changing your gear lube often if you tend to drive through water like many off roaders do. Else you are running a bearing destroying milkshake in your gearbox.
And ATF is the recommended lube in our transfer cases .
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 17 Old 03-07-2014, 10:38 AM
StanF
+1
I do exactly the same thing - no reason to go expensive
StanF is offline
post #10 of 17 Old 03-07-2014, 11:02 AM
rykemc
I run Mobile 1 synthetic 5w30 in my ax15 and t-case. Per the instructions from my transmission man.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #11 of 17 Old 03-07-2014, 12:04 PM
Siva283
This x2. My trans oil gets changed more often than my motor oil. Only thing changing the oil to often will do is waste money. Oil breaks down over time it doesnt get better.
Ask me how I know...
Siva283 is offline
post #12 of 17 Old 03-07-2014, 06:49 PM
mrdeath2000
It's up to you. I run the cheapo wally stuff, this time I actually put in 15w40 cause I wanted the 40w which is closer to the 90w gear oil. I'm also in AZ so 100-120* summers.
If cabbage isn't a worry, then sure, spring for redline's GL3 stuff everyone talks about.
Consider your climate, how often are you having to change the fluids because of water contamination? If it's often, then you better go wally 10.30 so you can still pay for gas.
post #13 of 17 Old 03-07-2014, 06:50 PM
bigbossd1030
I ran syncromesh in my tranny once. Then smartened up and found mean max's thread about what he uses. I've used castrol edge since. I buy it when it goes on sale for 2 for one. Costs about 20 bucks for a 5 litre jug. I don't do much water where I live, so I swap the tranny fluid every second oil change. Probably not necessary to do it that often (10k km) but that tranny has a lot of clicks on it. 307k actually. So I try to be kind to her.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #14 of 17 Old 03-07-2014, 07:29 PM
YJWookiee13
I used Redline MT90 right after i rebuilt my transmission last month, shifts beautifully!
YJWookiee13 is offline
post #15 of 17 Old 03-07-2014, 07:51 PM
89YJBuilder
I put what the Haynes manual says. Because they go with the transmission's manufacturer's specs. I also add 25% Lucas oil additive as I do in all my engines, transmissions, t-cases, and diffs. As Lucas recommends. Except for the Royal Purple I use in the wife Durango, I run it strait.
Keep your boogger hook off the bang button!
When all else fails... ham radio is there!
KG6YSF
89YJBuilder is offline
