Manifold on YJ's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Manifold on YJ's
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-11-2001, 05:06 AM   #1
HJ
Manifold on YJ's
I heard that it was a common fault to get a hairline crack at the manifold and so looked carefully to discover that there is a smear of exhaust sealant already present! Hmmm Apparently the manifold is steel tube and not cast iron so the best repair is to weld strengthen the original (as I also hear that a new part can be as expensive as £400 - and just as likely to fail.
Anyone had any experience of this?
Best wishes - Hwfa
Hwfa
HJ is offline   Reply With Quote Quick reply to this message
Unread 10-11-2001, 11:31 AM   #2
bonehead99
My manifold also cracked, I replaced it with a Pacesetter Armor-Coated Header for $300.00
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline   Reply With Quote Quick reply to this message
Unread 10-11-2001, 10:12 PM   #3
Nightclaw
I also got the hairline crack in my manifold. Or rather, the Jeep had it when I bought it, and it took me two months to really hear it.
Replaced with a Doug Thorley header (P/N 634Y), and have had no problems with the Thorley's material quality.
[b]'94 YJ Sahara Hardtop[/b]
4.0L / AX-15 / Stock NP231 / Stock D30 (open) / D60 (35-spline, Detroit locker, Moser axles) / rear disc brakes / 4.56 gears / Advanced Adapters SYE & CV Shaft / 33" BFG MT-KM's / Thorley Header / Magnaflow Muffler / BesTop Flares
Nightclaw is offline   Reply With Quote Quick reply to this message
Unread 10-30-2001, 01:47 AM   #4
HJ
Thanks for the advice folks - After consideration I decided to weld up the hairline crack in my exhaust, strengthening it at the same time. - there was room to do it I did it in situ. Seems fine
Best wishes
Hwfa
