Manifold gasket - JeepForum.com
post #1 of 2 Old 10-19-2013, 12:12 PM Thread Starter
Chase0808
Manifold gasket
After replacing my old carb with a MC2150 it has been running 100% better. The only problem I'm still having is a rough idle. There isn't any stall but the idle is choppy. I was told to spray carb cleaner around the manifold and carb to find any leaks. When I sprayed near the manifold the idle changed a lot. I'm thinking it is the gasket I'm going to have to replace.
Sent from my YJ
Chase0808 is offline
post #2 of 2 Old 10-19-2013, 02:08 PM
NonRubicon
Sounds to me like a manifold leak.
You can try re-torquing the bolts first, sometimes they can back out. If that doesn't help, the gasket is likely bad.
NonRubicon is offline
