Major shifting problems help!!!!!! - JeepForum.com
post #1 of 3 Old 09-06-2011, 09:08 PM Thread Starter
bbl32
I have a 95 yj, 2 inch body lift and shackle lift, 33's. When i got it, 2nd gear would scratch every now and then, but it's gotten really bad. Today it was so bad that i couldnt even put it into 2nd, it was grinding that bad. It grinds at high rpm's in 4th, but not in any other gears. Also when im at a stand still, if i put it in neutral and let the clutch out, it makes a slight rattling noise in my clutch/transmission area. Any ideas?
I was thinking maybe throwout bearing but i dont know why that would cause that much grinding on only one gear and not the others
bbl32 is offline
post #2 of 3 Old 09-06-2011, 10:13 PM
tsalmeto
Bad synchros?
A few years ago I had synchros go from bad to worse. At first it ground just a little, then really got bad. Made horrible noises, wouldn't shift and had to be rebuilt. I think the brass synchros disintegrated and jammed up the rest of the trans.
3 years later it's grinding from 3-4th now. I can ease it into 4th if I wait a second between gears. Can't downshift to 3rd at all though. No matter how long I wait it just grinds and won't go in. Just picked up another trans and will be swapping it out.
tsalmeto is offline
post #3 of 3 Old 09-07-2011, 03:15 AM
tankinyj
that sucks, sounds like your tranny is on its way out. defeinitely some bad synchos or your missing teeth on the gears
we had a saying at a construction gig i was doing a couple summers ago, while driving the trucks the owner told me the transmission is really bad, grinds into almost gear. the old saying was
"if you cant find it, just grind it"
tankinyj is offline
major water problems cjdelgrande YJ Wrangler Technical Forum 8 10-12-2010 07:12 PM
major problems plz help keffreg JK Wrangler Technical Forum 3 06-27-2009 10:29 PM
Major shifting problems. SEZARO21 YJ Wrangler Technical Forum 9 01-03-2009 06:21 PM
major spark problems. Drrm80 YJ Wrangler Technical Forum 2 11-04-2005 02:12 PM
Help Major Tj Problems thekrutchmaster TJ Wrangler Technical Forum 4 12-08-2004 09:22 PM
