Major Repair, Mean Max's AX-15 Rebuild QUESTION THREAD!!!! - Page 5 - JeepForum.com
 1Likes
post #61 of 194 Old 04-30-2012, 05:03 PM
idskot
Originally Posted by Winners97TJ View Post
You're askin the same question I asked my brother when I dropped my trans for my stroker build... His response made a lot of sense.
"You're asking if you should replace the synchro rings and bearings in the trans while it's out? The two most common issues with a manual transmission.... Why WOULDN'T you? It's about $300 for piece of mind even if they ARE in good shape after 150k miles. And that's an IF!"
I say rip it apart. It's a simple rebuild. Plus you'll learn a lot about it by going through it. Just be gentle when pulling the synchro rings and the engagement gears (not sure what they are called) with the round springs and "feet". They can be a pain to get them back to how they ate supposed to sit.
Yessir. That's what I thought! And thanks for the clicky.
idskot is offline
post #62 of 194 Old 04-30-2012, 07:22 PM
waves221
Which pilot bearing?
I am replacing the ax15 in my 93 yj with one from a 97 tj. What is the correct pilot bearing for this swap? Thanks
Jason
waves221 is offline
post #63 of 194 Old 04-30-2012, 07:45 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Jason
The '93 & later should have the 0.750" pilot bearing.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #64 of 194 Old 04-30-2012, 08:07 PM
waves221
Max
Do you know what the part number is on that? Thanks for the quick reply
Jason
waves221 is offline
post #65 of 194 Old 04-30-2012, 08:32 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Jason
I sure don't. I use LuK clutch kits in my shop, and they include the pilot bearing in the kit.
Max
Mean Max is offline
post #66 of 194 Old 04-30-2012, 08:51 PM
waves221
Max
No worries. Thanks again.
Jason
waves221 is offline
post #67 of 194 Old 04-30-2012, 09:06 PM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
Jason
That would be a 53009180AB for the 97 TJ.... about $18 at the stealership.
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #68 of 194 Old 04-30-2012, 09:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Use either Timken or National brand part number SCE1295 or equivalent. This part number applies to the '93 YJ 4.0L and the '97 TJ 4.0L models.
$6.81 @ www.rockauto.com
Max
Mean Max is offline
post #69 of 194 Old 04-30-2012, 09:34 PM
Winners97TJ
Go Big Or Go Home
Max
X2 on the timken.
post #70 of 194 Old 04-30-2012, 10:40 PM
waves221
X2 on the timken.
Thanks for the info guys. I am assuming that the release bearing and clutch/master cylinder from the 1994+ will work.
Jason
waves221 is offline
post #71 of 194 Old 05-01-2012, 05:54 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Jason
If you're swapping to an external slave, yes.
Also, use the YJ shifter.
Max
Mean Max is offline
post #72 of 194 Old 05-18-2012, 07:38 AM
Soldierfoley
Max, you are the man. This helped me a lot. However, I am having trouble with my clutch now. I have bled it 5 times, two times using the pump and hold method and 3 times just letting it bleed out on its own. My clutch feels good most of the time, but when I've been cruzing for while without shifting, the first push of the clutch is soft and does no good. A couple pumps and it's good for a while. Any suggestions?
Soldierfoley is offline
post #73 of 194 Old 05-18-2012, 01:01 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You still have air in the line. Often this can be accredited to a less than perfect o-ring seal between the master cylinder & the hose on '91 & newer models.
Max
Mean Max is offline
post #74 of 194 Old 05-19-2012, 01:47 PM
Soldierfoley
Mine is a 90. Any suggestions? Just keep bleeding it?
post #75 of 194 Old 05-19-2012, 03:00 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Actually yes! Luckily for you, your line has a threaded fitting at the master cylinder. Have an assistant pump the pedal & hold it while you crack the fitting open & then closed at the master. Most air occurs at the line where it loops over the master. Bleed it there first, then below as you normally would.
Max
Mean Max is offline
transmission , rebuild , ax-15 , repair
My 94 rebuild thread trucknut YJ Wrangler Technical Forum 53 06-22-2015 03:45 AM
Major Repair - AX-15 rebuild Mean Max YJ Wrangler Technical Forum 43 02-15-2014 05:01 AM
YJ major rebuild barney9393 YJ Wrangler Technical Forum 5 07-12-2006 06:36 PM
Anyone use Loctite thread repair? sentinal02 YJ Wrangler Technical Forum 9 10-07-2005 02:49 PM
