Major Repair, Mean Max's AX-15 Rebuild QUESTION THREAD!!!! - Page 3 - JeepForum.com
 2Likes
post #31 of 207 Old 10-12-2010, 01:22 PM
Supertrey
Max,
What would you estimate as YOUR time for doing the rebuild, not including removal and installation from the Jeep? I can figure out MY time based on your estimate.
Thanks!
Supertrey is offline
post #32 of 207 Old 10-13-2010, 07:12 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by Supertrey View Post
Max,
Thanks!
I pretty much take my time, if all goes well I can be done in about 6 hours or so. This includes breaks, and cleaning up the cases etc.
It could probably be done in half that time, but I'm doing this for fun so I really don't enjoy it if I rush.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #33 of 207 Old 10-13-2010, 09:07 AM
Supertrey
That helps a lot. My wife always multiplies the time I say it should take by 3, so that puts me in the 18 hour range!
Thanks!
post #34 of 207 Old 10-13-2010, 04:58 PM
Supertrey
One other question, is there anything in the transmission you recommend replacing besides what is include in the kit from Southwest Gear? Such as synchronizer assemblies (hub and slider), needle bearings, or fork?
If any other items are worth doing just to be on the safe side, now would be the time!
post #35 of 207 Old 10-14-2010, 08:04 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Actually most everything is covered in the kit, but there are some items you can add.
The oil seal in the shift tower.
Also check the cap in the shifter tip.
The 1-2 syncronizer sleeve. (because of the worn outer teeth for Reverse gear)
And the reverse idler gear, also due to worn teeth.
When shifting into Reverse gear it's common to have grinding. As the teeth wear on the 1-2 syncro sleeve & idler gear the grinding worsens.
Max
Mean Max is offline
post #36 of 207 Old 10-14-2010, 10:14 AM
Supertrey
Excellent! I will round those up as well. Thanks for your help Max.
post #37 of 207 Old 01-20-2011, 01:20 AM
Buzzstrike
Max, thanks for the pictorial breakdown on the AX-15.
Two questions.
1. Just how much pressure is needed to take off the 1-2 syncro hub. My 12 ton press is not moving it. (yes the snap ring has been removed) Damn thing is not moving.
ETA: I sneeked it in to work. Used the 50 ton air/pnumatic. That made it move. Guess it was stuck.
2. Have you seen bits of syncro keys (broken in half) at the bottom of the case. I found two out of three of the 3-4 syncro keys in that condition, along with a missing key spring? What would be the cause of that failure.
Bought a used trans with unknown problems. All that was said is that the oil was very "glittery" and was only a few ounces. All of the syncro's are toast, and every thing else like the syncro sleves, just needed to be deburred, and look good. All tolerances via the FRM are in spec.
Black Jeep Society Member
The rules of life.
1) Life is NOT fair.
2) Stupidity SHOULD be painfull.
3) Play stupid games win stupid prizes.
Buzzstrike is offline
post #38 of 207 Old 01-22-2011, 09:56 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Two questions.
Even after doing quite a number of rebuilds, that part always scares me. I really feel like I'm about to break something!
IMO, it probably all started with a severely worn/damaged 3rd or 4th gear syncro. this allows the key to get jammed up on the syncro where it shouldn't be (out of the key cut-out on the syncro) which typically "locks" it in gear. LOTS of force applied to the shifter breaks the key, then the circlip/spring falls out.
Max
Mean Max is offline
post #39 of 207 Old 01-22-2011, 05:32 PM
Buzzstrike
NOOOOO....
How in the hell do you crack the 5th gear synco hub
I follow the directions, took my time. I go to shift in 5th gear. NOTHING.
STUCK....
Take it all back apart. Tapped the syncro ring off of the hub.
Found the crack in one of the key channels. I don't think that was there before?
WTF???
Any one got a spare one laying around? anyone?
ETA: Well I found out WHY it happened.
Note: No4 synchro will NOT interchange with No.5. The cone of the synchro will not fit. damitdamnitdamnitdamnitdamnit. I just cost myself about another 150 bucks (well from Qtek) for a new gear assy, and I still have to get a clutch assy. FUUUUUDDDDGGGGGGGEEEEEEEE...........
doh...
The rules of life.
post #40 of 207 Old 02-26-2011, 09:06 PM
Nibbley15
NOOOOO....
STUCK....
WTF???
doh...
If you look at all your syncros you will notice that on 1 of the 5 it appears to have 2 small teeth, just barely visable. That is the 5th gear syncro.
Nibbley15 is offline
post #41 of 207 Old 03-17-2011, 10:51 AM
Supertrey
Max, There seems to be a lot of debate about fluids. Synthetics vs motor oil vs gear lube, etc . About to put in the freshly rebuilt unit, what fluid do you use?
post #42 of 207 Old 03-17-2011, 12:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I use conventional 10W-30 motor oil. There is a lot of debate on this subject, but it's what I use & have used for 60,000 miles since I rebuilt it.
Max
Sent from my HTC Incredible Droid
Mean Max is offline
post #43 of 207 Old 04-01-2011, 04:14 PM
Sleuthhound
Hey Mean Max, How many hours would you say the rebuild took?
My AX-15 seems to have something that feels like it's banging around when I put the clutch in. I can feel it in the shifter, and can hear it too. It's sort of a light banging (only ever seems to bang 3 times) like something is coming loose but hasn't fully separated yet. My Tranny mount looks good, but my engine mounts are shot. Think it's time for a rebuild?
Sleuthhound is offline
post #44 of 207 Old 04-01-2011, 07:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
For the first timers, I would plan on having it apart a few days. I know that sounds bad, but there are a lot of things you'll have to learn the hard way and this will cost you some time. Also plan on "backing up" a time or two because you missed something along the way. That's just how it goes.
Max
Mean Max is offline
post #45 of 207 Old 04-01-2011, 07:25 PM
Sleuthhound
Fair enough. I'm hoping to be able to do this with my dad, but I doubt that. I'm going to go back through your post and collect a list of tools I need, but is there anything you can suggest?
shop press, pry bars, snap ring pliers, anything else outside of ordinary sockets/wrenches ?
transmission , rebuild , ax-15 , repair
My 94 rebuild thread trucknut YJ Wrangler Technical Forum 53 06-22-2015 04:45 AM
Major Repair - AX-15 rebuild Mean Max YJ Wrangler Technical Forum 43 02-15-2014 06:01 AM
YJ major rebuild barney9393 YJ Wrangler Technical Forum 5 07-12-2006 07:36 PM
Anyone use Loctite thread repair? sentinal02 YJ Wrangler Technical Forum 9 10-07-2005 03:49 PM
