Major Repair - AX-15 rebuild - Page 2 - JeepForum.com
post #16 of 44 Old 08-24-2010, 01:10 PM
djsmith1174
Max,
I have a question for you regarding the AX-5 2nd gear and hub. There is no snap ring on the AX-5 hub like there is on the AX-15. But I pressed on 2nd gear last night and could not get the hub to budge off the splines. Is there something that I'm missing?
Thanks,
Daren
djsmith1174 is offline
post #17 of 44 Old 08-28-2010, 11:22 PM
mylightsrsquare
all i can say is WOW
makes me want to buy an ax 15, rebuild and put it in my 88. if i do do that one day i WILL fallow this step by step
thanks
1988 yj. 4.2l with a Weber and an ax15 swapped in
mylightsrsquare is offline
post #18 of 44 Old 09-05-2010, 01:21 PM
djsmith1174
Just wanted to give another thanks to Max for this write up. It was invaluable during my AX-5 rebuild.
post #19 of 44 Old 09-05-2010, 01:26 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks for the kind words!
The AX-5 & AX-15 are almost identical, so much of the info will help with the AX-5 as you already know.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #20 of 44 Old 09-05-2010, 02:25 PM
lonepunker
wow...... good work can you do mine? I'll give you a nice new crispy dollar bill!
E CLAMPUS VITUS
Billy Holcomb chapter 1069
lonepunker is offline
post #21 of 44 Old 02-26-2011, 08:38 PM
Nibbley15
I wanted to say Thanks!
I followed your directions, and have everything back together except for putting the cases on. Not taking the shifting arms out saves time! I read these steps 6 times then was able to do it all from memory, I only printed off the pictures of the parts breakdown so I could make sure I had all parts in the right order.
Thanks again!
Nibbley15 is offline
post #22 of 44 Old 02-26-2011, 11:00 PM
boybadone
Thanks Max! I am considering rebuilding my AX-15 this summer and this will be invaluable.
boybadone is offline
post #23 of 44 Old 05-30-2011, 03:20 PM
smartt
First I just wanted to say let you know how much this thread helped with my rebuild. Secondly I would like to add some points as I just completed my rebuild and found some easier/different ways to do things.
-When lowering the transmission while still attached to the engine, you may lower the transmission down alot further than 3". I had mine down about 8" which makes access to the top two torx bolts much easier.
-Once the torx bolts are removed, my recommendation is to just reinstall regular bolts in the top two locations on the bell housing. This makes for an easier removal in the future.
-The most helpfull thing that I found out during the process of this rebuild was that once the bearings are removed from the shafts using a press, they DO NOT need to be pressed back on. The easiest way to reinstall any of the bearings or gears that you have to press off is to simply heat them with a torch. Heat the inner ring of the bearing, making sure not to heat to much of the outside directly, as many of the bearings have not metal pieces. When the bearing is good and hot simply put on some gloves and slide the bearing in place. You want to let mother nature work for you.
Hope this helps someone, as I just finished my tranny rebuild this weekend.
smartt is offline
post #24 of 44 Old 02-06-2012, 09:20 PM
Eloranta95yj
AX 15 rebuild of my own
Hey there, a few months back i bought a 95 yj and was driving along one day in second gear when i heard a loud clunk and from that moment on the shifter was stuck in neutral position, wouldnt even grind when i tryed to put it into gear.
Luckily i had a 93 yj sitting in the backyard with same motor and trans. It took me two days to do the swap and once i had her in place, the thing ran beautifully. Now(three months later), me and my buddy decided we should take the old one apart and see what went wrong.
I am very excited to see what you have posted here, and i will be documenting mine as well.
Do you have any ideas to what may have gone wrong inside this thing?
Eloranta95yj is offline
post #25 of 44 Old 02-27-2012, 07:55 PM
patnewk76
Max, thanks for this thread. Mine is looking at a rebuild in the near future and this will help greatly. 1st and 2nd do fine shifting, but I grind when shifting to 3rd and 4th and on the rare cases 5th unless I hold in on the clutch for afew secs. looks like i still need to get a couple tools. I liked how you told the sizes of the wrenches and such. thanks again
91 YJ "Tonka" 4.0/ax15, stock/stock axles,
99 WJ 4.0 work in progress
patnewk76 is offline
post #26 of 44 Old 04-27-2012, 06:45 PM
Soldierfoley
Just used this to take mine apart. Lets see if I can get it back together when my parts come in.
Soldierfoley is offline
post #27 of 44 Old 05-10-2012, 06:06 AM
Soldierfoley
I got mine back together. It went too easy. I was expecting something to go wrong.
post #28 of 44 Old 04-01-2013, 11:17 PM
JeepProblems
hey there, great write up! just finished putting my ax5 back together but it wont shift with the case on > any ideas?
do i have something flipped around? i followed step by step putting each detent balls and springs back in their homes..
JeepProblems is offline
post #29 of 44 Old 04-01-2013, 11:19 PM
JeepProblems
also, havent really used any lube other than petro jelly on the rails and balls/pins. the only oil i used was pen synchromesh on the needle bearings. could this be why its not shifting? it shifts just fine with the case off though..
post #30 of 44 Old 04-02-2013, 12:05 AM
kbson
After I zipped mine back up after doing the rebuild I was having the same problem when I was trying to test shift it on the bench...or at least I thought I was having a problem. I thought the same thing as you--maybe a detent ball in the wrong place or something. I was about to open it all up again, when I decided to think on it for a while. After a couple of hours my brain clicked. I was trying to move the shift rails incorrectly. There was nothing wrong with the transmission. I was sticking a socket extension in where the shifter goes and trying to simulate the motion that I normally use when shifting with the shifter. Don't know if I can explain it in words, but I was trying to tilt the socket extension like a lever but I needed to push/slide it straight forward or backward (no bending my wrist). Then it worked--because that's the way it is supposed to work Maybe you are smarter than I was, but that was my problem. Also it takes considerable force to shift it when using something short (like a socket extension).
kbson is offline
ax-15 , pics , pictorial , rebuild , tear down , write-up
yo rebuild or not to rebuild that is thi question njdpb22 YJ Wrangler Technical Forum 22 12-01-2010 08:07 PM
Rust Repair!~ Bad Idea? Fiberglass Repair tirogers YJ Wrangler Technical Forum 18 02-16-2010 08:06 PM
Jeep Engine to Rebuild or Not to Rebuild booyia TJ Wrangler Technical Forum 31 10-02-2009 01:16 PM
major boo boo blamejane2 YJ Wrangler Technical Forum 5 12-14-2008 02:36 PM
YJ major rebuild barney9393 YJ Wrangler Technical Forum 5 07-12-2006 07:36 PM
