Major Oil Leak - JeepForum.com
post #1 of 10 Old 07-29-2010, 05:31 PM Thread Starter
thunderstar99
Major Oil Leak
I was hoping someone here could help me out. I have a major oil leak on thre lower passenger side of the engine block. I wish I knew how to put a pic on here but will try to decribe it the best I can. There is a pipe(?) coming out and then it y's there is a black piece that sticks straight up toward the hood that has a single wire. The other side of the Y has another piece coming out and has two wires connected to it that is where my leak is located. I looked in the haynes manual and could find nothing. Stopped by Advance Auto Parts and they said that it was the oil pressure sensor. What they g=had looked like the piece sticking straight up to the hood. Any help would be greatly appreciated. I really need to get this fixed before I go to Afghanistan so the wife doesnt have to worry about it. Again thank you for your help
P.S. almost forgot 1990 4.2L I6
thunderstar99 is offline
post #2 of 10 Old 07-29-2010, 08:45 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The one that is pointed up is the oil pressure sending unit. The one that points sideways is the oil pressure switch.
The OEM # I find for the OPSU is 5300 5218.
The OEM # I have for the OPS is J575 8695.
Good luck and keep safe!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 10 Old 07-29-2010, 09:07 PM
4LarXedo4
Top right diagram sounds like what your describing, ^ like stated above sending unit and switch. Advance auto should have both I got both mine from there pretty cheap.
IG: YJ4Point2
HEMI Club Member #48
4LarXedo4 is offline
post #4 of 10 Old 07-29-2010, 09:48 PM Thread Starter
thunderstar99
Thank you for the reply. I am still figuring my jeep out and trying to learn as I go. I am really appreciative of all the help I have gotten on this forum. William
post #5 of 10 Old 07-30-2010, 07:30 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
You are welcomed! Forums work so well because many of us have some knowledge about some things to use or share.....but our significant others usually don't think we know crap about anything!
post #6 of 10 Old 08-30-2011, 01:28 PM
Peanuts89yj
i swear mine is leaking fro wher distributor mounts to motor. i it bubble there at cold start and drip spot is right below....was told it was sending unit or switch but diagram from above says otherwise. leak comes from above oil filter ..filter is new and leak was ther b4 oil change and with old filter. gy at valvoline told me to put a handfull of sawdust into the engine to "gum up" the leaks....sound like not a good idea. any thoughts on my leak? HELP! PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Peanuts89yj is offline
post #7 of 10 Old 08-30-2011, 01:30 PM
Andywear
sawdust FTW
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #8 of 10 Old 08-30-2011, 01:48 PM
Old4X
1990 CJ7
Therer is a gasket on the distributor flange. It could be broken or missing.
Check your PCV system. If it is working properly and you have the proper amount of vacuum (engine properly tuned), you should not be leaking there.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 10 Old 08-30-2011, 08:28 PM
bioman
Check the distrib seal and if you still have the problem check the pcv. You may be pressuring your crank case a bit. But I think the distrib seal from what I hear.
Bioman
bioman is offline
post #10 of 10 Old 09-06-2011, 12:51 PM
Peanuts89yj
I also think I should mention that I dont think the vaccuum lines for the 4wd r hooked up. And the hose that comes off the air intake on the top of the head closest to the radiator, that fits loosely, looks like silicone dried and it cracked. Guy I bought from did the MPI kit w/ 4.2 block 4,0 HO head etc. never swapped tac to correct voltage so i have no tac. And honestly i have never needed to put it in 4wd. where I go in N.H. is dry and rocky, no real steep stuff.. And i am assuming if i had a spun bearing not letting oil pass it would pour out rear main seal at crank, not at dist seal. Working on my harley seems way easier...lol
Major Oil Leak gnarboots YJ Wrangler Technical Forum 17 07-30-2010 10:18 AM
Major Gas leak andrewf09 YJ Wrangler Technical Forum 16 02-21-2010 09:28 AM
Major oil leak repaired for $2.92 bernm8r YJ Wrangler Technical Forum 2 07-25-2009 08:38 AM
Major oil leak Wrangler91 YJ Wrangler Technical Forum 5 03-30-2008 08:34 PM
help, major leak! BobbyHill YJ Wrangler Technical Forum 2 06-08-2002 12:32 AM
