Major Oil Leak - JeepForum.com
post #1 of 18 Old 07-28-2010, 09:21 PM Thread Starter
gnarboots
Major Oil Leak
My 88 YJ is leaking a lot of oil. Driving down the road or at a stop sign I can see a lot of smoke from the oil dripping onto the exhaust. From underneath it looks like it is coming from somewhere above, dripping onto the tranny near the oil pan and back on one of the skid plates, but cant quite tell where it is coming from, but there seems to be more oil on the passenger side... The oil sending unit looked fine and the valve cover seal doesn't look like it is leaking much, if anything at all. Does anyone know of anything that commonly leaks with these models. It is a completely stock 258 with a newly installed Weber. Thanks for reading!
gnarboots is offline
post #2 of 18 Old 07-28-2010, 09:24 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Degrease, pressure/steam wash & reinspect.
Joe Dillard is offline
post #3 of 18 Old 07-29-2010, 12:07 AM
JPRatYJ
FIRST i would clean it just like Joe Dillard said then I would make sure your pcv system is working and if its not theres your problem... but the damage could already be done and you would wind up having to replace almost every gasket...(oil pan, rear main, valve cover, pcv gromlets) I just had to do this to mine after i did the weber 3 months ago...
/l ,[_____], 1990 YJ 4.2 Weber 34
l---L -[]lllllll[]- 4in Rustys, 3in body, 1.25 Shackles
()_) ()_)--o-)_) 33 Kumo's M/T and smittybilt tube fenders -----Johnny Rat-----
JPRatYJ is offline
post #4 of 18 Old 07-29-2010, 06:55 AM
pasinbuy
I will never pressure wash my motor, you may or most likely will do more damage. Buy about two to three cans of engine degrease spray and clean everything well. Rinse, Then inspect that everything is perfectly clean, reapply if needed, scrub heavy spots with a brush or rag, Rinse, Dry or let dry. Then drive about one mile, let it cool, then look or feel around. Find your leak.
pasinbuy is offline
post #5 of 18 Old 07-29-2010, 11:02 AM
jsawduste
2006 YJ Wrangler
Why ?
Many folks do it all the time. A little common sense goes a long way.
This one has been pressure washed many a time.
This YJ (mine spends most of it`s time off road playing in the mud.
jsawduste is offline
post #6 of 18 Old 07-29-2010, 01:08 PM Thread Starter
gnarboots
Yesterday I began degreasing most of of the engine but ran out of daylight. So today I will continue and see if I can find anything. Thanks for the tips guys, I will post anything I figure out.
post #7 of 18 Old 07-29-2010, 05:31 PM Thread Starter
gnarboots
If I haven't properly plugged off and removed a lot of the vacuum lines and hoses for the old carter, will the PCV system work okay?
post #8 of 18 Old 07-29-2010, 06:31 PM
GRYDE001
Originally Posted by jsawduste View Post
Why ?
wow, that's one good looking engine bay!!
I use simple green on my engine. Let it sit for a few and wash off with a garden hose and it looks 100% cleaner. I've got a small oil leak too. I cleaned my CCV system and that seemed to help matters some.
also, check your oil sending unit, I've read that they are prone to break and leak.
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline
post #9 of 18 Old 07-29-2010, 07:19 PM
pasinbuy
Why ?
This one has been pressure washed many a time. This YJ (mine spends most of it`s time off road playing in the mud.
It is too easy to damage a seal or a gasket. Forget common sence accidants happen with a pressure washer and a motor. I run pressure washing crews in my business so I do know how to do it if I wanted to. And with that knowledge I will not pressure wash a motor. It is too easy to make a mistake and a little degreaser and water from the hose nozzle does the same job and even better.
By the way from the looks of your setup, I doubt that you spend allot of time in the mud, also considering what you did to me in another thread http://www.jeepforum.com/forum/f12/y...t-mod-1077482/ and the names that you called me. I would prefer that you do not respond to my threads or replies in the future.
pasinbuy is offline
post #10 of 18 Old 07-29-2010, 07:34 PM
jsawduste
2006 YJ Wrangler
Sorry but you are wrong. I even use the YJ for bogging. It all boils down to how much care, attention and detail you are willing to spend.
Too bad if you think I am pissing in your Cheerios. Your opinion differs from many others.
post #11 of 18 Old 07-29-2010, 08:10 PM
pasinbuy
To bad if you think I am pissing in your Cheerios. Your opinion differs from many others.
Dude I looked over at you replies to others on this Forum and you are a jerk. Not just to me but to everyone... I see where you call other Forum member clowns, stupid, dumb, etc. It seems that you spend allot of time insulting the people on this Forum and then asking to see their girlfriends.. I for one have been one of your victims of your name calling.
Please go away, You are the only person that acts this way on this Forum.
pasinbuy is offline
post #12 of 18 Old 07-29-2010, 08:43 PM
jsawduste
2006 YJ Wrangler
Call it like I see it. If someone deserves to be insulted for lack of the most basic common sense then so be it.
My alternator caught on fire.........Is this normal ?............
Now you are telling me how I wheel my Jeep. How do you know ?
To the OP.
On the passenger side, back of the block, just below the head is a tapped in plug. This plug used is to cover the machining of the block for the camshaft.
While not to common, this plug has been known to leak. Often times the cam will ever so slightly walk back and touch this plug. Ultimately wearing a hole in the plug and causing an oil leak as you describe. You might want to check this.
post #13 of 18 Old 07-29-2010, 09:18 PM Thread Starter
gnarboots
Thanks I will have a look see tomorrow if I get the time. It does seem like it's coming from somewhere back behind the head and maybe running down the block where I can't see anything, couldn't accomplish much today though...
post #14 of 18 Old 07-30-2010, 09:56 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Can we get this train wreck back on topic here.............
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #15 of 18 Old 07-30-2010, 10:08 AM
taormina92
Why ?
That's sweet, dude. My engine bay looks that clean except not that fancy with all the blue hose. I can't believe how people post pics up of dirty engine bays regular here....don't people know that a clean engine bay is the first step in diagnosing an engine problem......all leaks and their sources are therefore obvious!
taormina92 is offline
oil leaking
Major Gas leak andrewf09 YJ Wrangler Technical Forum 16 02-21-2010 09:28 AM
Major oil leak Wrangler91 YJ Wrangler Technical Forum 5 03-30-2008 08:34 PM
major leak in EVAP? rinterr TJ Wrangler Technical Forum 3 12-07-2006 07:48 AM
Need major help water leak BIGWILL78 YJ Wrangler Technical Forum 4 09-27-2006 08:07 PM
help, major leak! BobbyHill YJ Wrangler Technical Forum 2 06-08-2002 12:32 AM
