Major issues what to do?!?!? - Page 2 - JeepForum.com
post #16 of 57 Old 03-12-2014, 10:32 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Originally Posted by jeepguy85 View Post
I see you are in Greeneville. I live in Kingsport. If you need some help, pm me. I agree to check the ECM. It could be going out.
This is why I love this forum! Nice job, Jeepguy.
Welcome to the Forum Tnjeeper.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #17 of 57 Old 03-12-2014, 10:59 PM
whiskeywiz
Have you checked the cap for corrosion?
I have gotten in the habit of starting a job by removing the faulty part first. That way, (for example), if I "think" my brake pads are bad I can verify it before throwing money at it.
That said, don't run out and buy a new cap. Take the old one off and check it out first. Might just need some sandpaper!
Even when I'm sure I know what part is bad, (such as brake pads), I still wait to go to the parts store until after I remove the bad parts because you never know what else you are going to find.
whiskeywiz is offline
post #18 of 57 Old 03-12-2014, 11:06 PM Thread Starter
Tnjeeper89
Yes whiskey I checked it looks new still I replace it when I replace coil and plugs along with rotor button
Tnjeeper89 is offline
post #19 of 57 Old 03-12-2014, 11:17 PM
whiskeywiz
what is the weather like when it is acting up on you? Is it raining?
post #20 of 57 Old 03-12-2014, 11:40 PM Thread Starter
Tnjeeper89
Nope it started acting up on a clear warm day the next day was warmer and did it again then when it died it was cool about 40. But no rain on any if the issue days. It's hasn't started up since the night it died.
post #21 of 57 Old 03-13-2014, 06:07 AM
whiskeywiz
Have you checked the fuel pressure?
You can get a pressure gauge cheap at Harbor Freight.
Nice tool to have, fuel pressure reading will tell you if your problem is fuel delivery or not.
You could just depress the valve stem and see for gas stream, but may not be accurate enough. Sometimes a few psi is all it takes.
post #22 of 57 Old 03-13-2014, 07:53 AM
jeepguy85
1987 YJ Wrangler
I have been thinking about this. When it acts up do your gauges die or go crazy? I have seen that happen and it it usually the ecm.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #23 of 57 Old 03-13-2014, 11:13 AM
whiskeywiz
Maybe he got the wrong size injectors? Could be sales error.
post #24 of 57 Old 03-13-2014, 11:39 AM
Why J?
Why J?'s Avatar
He has zero fuel pressure. The fuel pump is not running.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #25 of 57 Old 03-13-2014, 12:00 PM
AZJEEPGUY1
Check the fuse
AZJEEPGUY1 is offline
post #26 of 57 Old 03-13-2014, 12:01 PM
AZJEEPGUY1
Check the fuse box for a short
post #27 of 57 Old 03-13-2014, 12:01 PM
jeepguy85
1987 YJ Wrangler
He also has no spark. I would check all the grounds to make sure they are in good shape. It almost sounds like a dead short in the electrical somewhere.
post #28 of 57 Old 03-13-2014, 12:08 PM
whiskeywiz
I gotta give this a re-read
post #29 of 57 Old 03-13-2014, 12:15 PM
whiskeywiz
So he's got 2 issues, no spark AND no fuel? Geez. He said he replaced the fuel pump. Does that mean it was used or new?
89 fuel pumps are very similar between multi port and tbi or efi but ARE NOT interchangeable and will not function if the wrong one.
post #30 of 57 Old 03-13-2014, 12:20 PM
jeepguy85
1987 YJ Wrangler
So he's got 2 issues, no spark AND no fuel? Geez. He said he replaced the fuel pump. Does that mean it was used or new? 89 fuel pumps are very similar between multi port and tbi or efi but ARE NOT interchangeable and will not function if the wrong one.
It also started and he drove it after the swap so I don't think that is it either.
