Hey Jeepers, my maintenance required light on my dash is on and has been for a while. The jeep is a 92 yj 2.5 with approx. 170 kms. on it .. Ive heard that this light will pop up after 150 k's. Any truth to that?? Just gave her a major tune up and such but the damn thing is still there. Thinkin of pullin the bulb from the dash..Yikes!! Thanks for yur help guys.. :wave:
Normally the light indicates a problem with emissions. It could be something as simple as a disconnected vacuum line, a bad O2 sensor, etc.
IMO disconnecting the light will cause no harm, as the problem is probably not serious. If you live somewhere where they do vehicle inspections, and they test your emissions, then you may have a problem.
If I'mway off base, I'm sure someone will correct me... :thumbsup:
At 82,500 miles the engine light will come on as a sign to replace the 02 sensor. Not sure on how many KM's that is, but it could be just that. Or more likely that something isn't sitting right with your jeep after that "major" tune up. If you did something like put in a lower Tstat or something the engine light might come on. Check your codes, disconnect battery and reconnect, drive it, and check for codes. that should be a good indication of if any problem is there.
My light never came on though at 82500 miles so not real sure what to tell you.
That light is not indicating anything wrong with the Jeep. As stated earlier it is in the computer to come on @ around 82K miles. Your local dealer can hook it to a computer and turn the light off. Mine did it for free. Took all of 10 seconds.
I'm pretty sure all the maintenance required light is for is to tell you to change the O2 sensor at some set milage. When the light comes on it doesn't mean the O2 sensor is bad, it means the sensor should be changed because that is the recomendation from the factory. The check engine light will tell you when there is a problem with any of the sensors including the O2 sensor. So if you don't want to bother with it right now either ignore the light, pull the bulb, or bring it to the dealer to have it reset.
02 sensors are to be replaced every 50K miles, from the manuals i've read. It just never made sense to me why the factory waited till 82K miles to have the light come on......oh wait, maybe it was that whole 80K mile emissions warranty thing. hmmm?
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
