Maintenance required light came on? - JeepForum.com
post #1 of 10 Old 12-23-2004, 08:05 AM Thread Starter
DevilDogJeep
DevilDogJeep's Avatar
I know what to do when my engine light comes on but what the hell is the maitenance required light trying to tell me. How do I firgure it out without going to the stealer-ship?
/I,[_____],
L---L--[]IIIIIII[]
()_)()_)--------)_)
92 Wrangler
2.5L No mods yet! Besides 31's.
87 Wrangler W/258 stock and even missing parts.
DevilDogJeep is offline
post #2 of 10 Old 12-23-2004, 08:37 AM
Silver yj
The light comes on at certain mileage,it reminds you to have things checked over like emissions and so on.
Silver yj is offline
post #3 of 10 Old 12-23-2004, 08:50 AM
oct7brian
oct7brian's Avatar
Do what I did just take the bulb out. I dont have factory exhaust and it didn't effect my emission output to I just pulled the bulb problem solved!! But really if you have emission tests you might want to have it looked at
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #4 of 10 Old 12-23-2004, 08:57 AM
pouponu73
The maintenece required light is on a timer that tells you when your O2 sensor is due to be changed. I think the timer is set for 85000 miles The only way to shut it off is to replace the timer. Just take out the bulb and the problem is solved
pouponu73 is offline
post #5 of 10 Old 12-23-2004, 11:33 AM
OlllllllO Jeep1
Actually on a 1992 the timer light is able to be turned off, I got mine to shut off, I think by just replacing the O2 sensor. I do believe that was at 85,000 miles. For some reason mine came back on, when I was in the garage for a diagnostic check the tech just reset it with a scan tool and the thong has been off for the last 10,000 mi. I think on the older models yopu have to take the bulb out or whatever. If the light bothers you just stick some tape over it until you can figure it out or have someone reset it. I think it may say how to do this in the Haynes I will look later.
OlllllllO Jeep1 is offline
post #6 of 10 Old 12-23-2004, 11:54 AM
Upstate Chili
Upstate Chili's Avatar
If you have the timer just unplug it. It's on the firewall in front of the shifter.
Upstate Chili is offline
post #7 of 10 Old 01-06-2005, 06:55 AM Thread Starter
DevilDogJeep
What does the timer look like?
/I,[_____],
L---L--[]IIIIIII[]
()_)()_)--------)_)
92 Wrangler
post #8 of 10 Old 01-06-2005, 06:26 PM
Upstate Chili
Like this
post #9 of 10 Old 01-06-2005, 06:34 PM
wherndon
What the hell?
wherndon's Avatar
wow!
that thing actually has clockwork gears in it.
________________________________
'05 Rubi, Patriot Blue, RE SF, Antirock, Warn, Fabtech, Tomken
_________________________________
2000 Grand Cherokee Laredo V8, Patriot Blue
Stock
'93 YJ Sport, Canyon Blue
4.0, auto, air, limited slip, HT.
2.5" Rancho suspension, Ramsey 8000
Previous Jeeps...
'91 XJ Laredo, white
'87 YJ Sport, white
wherndon is offline
post #10 of 10 Old 01-06-2005, 11:34 PM
Questor
Questor's Avatar
Just had mine cleared at the dealer with the DRB II - most of the time they will do this for you at no charge.
The FSM confirms that the ONLY function of the Maint Req'd light is to remind the owner to replace the O2 sensor and other components and that it is only triggered by time... for older models ('91 is when they changed it I think) the timer was semi-mechanical, for newer ones it's all electronic and based on cycles of ignition timing, so there's no set way to know how many actual miles will fire it - I've heard that lots of high revving will cause it to fire sooner.
Also, it's not indicitave of the actual state of your O2 sensor at all, it's just a 'good idea' to replace it every 80k...I've got a nice O2 sensor tester that lets me check the condition of O2 sensors...neat tool. Replacing the sensor alone will not shut off the light.
...talk about generating repeat business for the dealers...
'92 YJ Sahara / OME / BFG AT/TA - a few other rides.
Questor is offline
maintenance required light onlyjeep YJ Wrangler Technical Forum 18 09-19-2009 07:46 PM
maintenance required light JeepMKcomin YJ Wrangler Technical Forum 12 03-20-2008 08:15 AM
maintenance required light please help slmcook YJ Wrangler Technical Forum 10 02-26-2005 06:37 PM
Help...maintenance required light a204600 YJ Wrangler Technical Forum 7 01-04-2005 02:25 PM
Maintenance required light..Whats up with that?? sturgman YJ Wrangler Technical Forum 5 12-16-2003 07:43 AM
