maintenance required light - JeepForum.com
post #1 of 19 Old 11-20-2008, 09:48 AM Thread Starter
onlyjeep
2011 JK Wrangler
im working on a jeep that i bought last sept. and the maintenance required light is on,
can anybody help me out how to reset this.
put a new o2 sensor on it
1989 jeep 4.2
onlyjeep is offline
post #2 of 19 Old 11-20-2008, 09:57 AM
jbolty
jbolty's Avatar
that thing operates on some combination of time and/or miles. The time is under the dash usually just above the gas pedal and is a plastic box with what looks like clockwork gears in it. Unplug and toss in the trash.
jbolty is offline
post #3 of 19 Old 11-20-2008, 01:55 PM
GrimJeeper91
GrimJeeper91's Avatar
This is what you are looking for...
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #4 of 19 Old 11-20-2008, 02:15 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Unless cali is anal about that, it is time to remove that little black box man. All it does is tell you when to go back to the dealership. Usually for emissions replacement. Not a big deal.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 19 Old 11-20-2008, 04:13 PM
ctm
don't just toss it in the trash.
First smash it with a hammer and run over it several times, then toss it in the trash.
ctm is offline
post #6 of 19 Old 11-20-2008, 05:06 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
First smash it with a hammer, run over it several times, shoot it with a politically incorrect fire arm, club it with a baby seal and only then toss it in the trash.
Fixed it for you...
Some states require all immision equipment to be intact for an inspection sticker. Check local laws for compliance requirements
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #7 of 19 Old 11-20-2008, 06:50 PM
UnFocused
If you look at the backside of the unit that GrimJeeper91 posted, you'll find a label that says "Made in Taiwan" or something like that. Peel the label back and there's an access slot to the gears. Look closely and you'll see a single spring loaded wire that's touching an electrical stud; that stud is connected to the wire which turns the maint light on.
Take a toothpick or small screw driver and move the spring loaded wire out the the edge of the white plastic gear nearby. You'll discover that it has a recessed track running around the outside edge which the wire will drop into. Leave the wire parked in that outside track. As the gears rotate, sooner or later (about 2750 hours or so) there will be a bump in the outside track which raises the wire and once again lets it slide into the electrical stud where you initially found it.
UnFocused is offline
post #8 of 19 Old 11-20-2008, 07:22 PM
ZeroGravity
So it's just a way to sucker people into thinking their car needs work by the dealership?
My light has been on since August.
ZeroGravity is offline
post #9 of 19 Old 11-20-2008, 07:36 PM
UnFocused
It's just a simple clock motor; it's only purpose is to signal when the O2 sensor should be replaced. I guess some engineer decided that 2750 hours was the magic time; curiously that works out to 82500 miles at an average speed of 30 mph although I'm completely uncertain if that means anything or not.
post #10 of 19 Old 11-21-2008, 07:43 AM Thread Starter
onlyjeep
2011 JK Wrangler
thank you guys for all your input
You' ve been very helpfull
onlyjeep is offline
post #11 of 19 Old 09-18-2009, 01:19 AM
MLTXJ9889
1992 XJ Cherokee
Is this the same box as what would be on my 92 cherokee. Mine came on tonight.
MLTXJ9889 is offline
post #12 of 19 Old 09-18-2009, 09:12 AM
idaholtby
No, with 1991 and up, the maintenance timer is incorporated into the ECM. These years do not have the box under the dash like the '90 and earlier models do. In your case with the '92, remove the maintenance required bulb in the dash and be done with it.
idaholtby is offline
post #13 of 19 Old 09-18-2009, 09:42 PM
MLTXJ9889
1992 XJ Cherokee
You dont have to do that and you also don't need to go to dealerships to get it shut off. I looked at it on my lunch today at work and got it shut off. You can shut it off with a Snap On Modis scan tool. It tricks the emission system and resets it.
post #14 of 19 Old 09-18-2009, 10:46 PM
Fhajad
My 93 doesn't even have the maintence required light.
Fhajad is offline
post #15 of 19 Old 09-19-2009, 06:28 AM
rustywrangler
yours should be an emissions light or something similar.
maintenance required light JeepMKcomin YJ Wrangler Technical Forum 12 03-20-2008 09:15 AM
Maintenance Required Idot Light GrimJeeper91 YJ Wrangler Technical Forum 29 02-05-2007 09:48 PM
maintenance required light please help slmcook YJ Wrangler Technical Forum 10 02-26-2005 07:37 PM
Maintenance required light came on? DevilDogJeep YJ Wrangler Technical Forum 9 01-07-2005 12:34 AM
Help...maintenance required light a204600 YJ Wrangler Technical Forum 7 01-04-2005 03:25 PM
