maintenance required light - JeepForum.com
post #1 of 13 Old 03-19-2008, 05:20 PM Thread Starter
JeepMKcomin
How do I get the maintenace required light to go off on a 1992 2.5L YJ. I'd like to do it however the factory does it rather than rig something.
Do I need an obd1 codes reader/clearer or can I reset myself?
Sorry if this is beating a dead horse. I'm new to the YJ world and didn't see this in the faq when I was reading through or get much help from search.
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #2 of 13 Old 03-19-2008, 05:30 PM
Rush1184
It has one? With all the problems I have had with my YJ, I have never had mine go on, lol.
Sorry I could not be of any help.
1993 YJ Green/Spice - 6cyl 4.0L AX-15
2x KC Daylighters on windshield hinges, front hooks, rear shackle, 20' strap, shovel, saw, tools, air compressor, etc.
FOR SALE:
- Set of 4 used 33x14.5r15 Mickey Thompson Baja Belted HP Tires on Alloy Rims (5 on 5.5 bolt pattern).
- 2x white 6" KC Stone Guards (NEW)
(PM me if interested)
Rush1184 is offline
post #3 of 13 Old 03-19-2008, 05:35 PM
pat8942
pat8942's Avatar
You need the special Chrysler code reader to turn it off.
DRB I think they call it.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #4 of 13 Old 03-19-2008, 05:35 PM
xxxflhrci
xxxflhrci's Avatar
If if is like the one that is on my YJ, it is nothing more than a mechanical timer. You can unhook it and the light will go out. It is nder the dash above the gas pedal. It is a clear black plastic box with some plastic gears in it that you can see. Just unplug it.
xxxflhrci is offline
post #5 of 13 Old 03-19-2008, 05:39 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
black plastic box above gas pedal. it is a timer for the emmisions junk....
either unplug the box, or remove the bulb. your call.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 13 Old 03-19-2008, 05:59 PM
pat8942
pat8942's Avatar
Thats for pre-91 the newer ones are wired into the PCM.
pat8942 is offline
post #7 of 13 Old 03-19-2008, 06:00 PM
leftlanetruckin
XJ on 37's
mine was a 91 and it came on. i think i just unplugged the damn bulb myself, but thats just me......
it did have the box under the dash though...
martin
post #8 of 13 Old 03-19-2008, 06:54 PM
pat8942
pat8942's Avatar
It might have been one of them transitional vehicles.
I hate it when they do that.
martin
pat8942 is offline
post #9 of 13 Old 03-19-2008, 07:13 PM
leftlanetruckin
XJ on 37's
yeah, the 91 was the oddball yj for sure.....
martin
post #10 of 13 Old 03-19-2008, 07:18 PM
jeepsurf
Yea I've got that on my 90. Is that required for inspection or can I rip it out?
jeepsurf endorses this post. Most of the time
1990 2.5 YJ / 1997 2.5 TJ
USAF VET
My YJ build thread
Nightcrew alive and well, now on VB 4.0
Food mailed 3ooo miles
jeepsurf is offline
post #11 of 13 Old 03-19-2008, 07:22 PM
leftlanetruckin
XJ on 37's
rip it out.....
martin
post #12 of 13 Old 03-20-2008, 07:33 AM
TSEJEEPERS
Not sure if they have a scanner for ob1 but you could take it to Auto Zone. Have them read the code and they can turn off the check engine light too.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #13 of 13 Old 03-20-2008, 08:15 AM
NewhampshireYJ
Mine has been on for a few months. I gotta just take that damn bulb out.
1993 Black YJ
All Terrain 33's-4 inch RC lift
Revolver shackles- some other stuff
NewhampshireYJ is offline
maintenance required light onlyjeep YJ Wrangler Technical Forum 18 09-19-2009 07:46 PM
1991 YJ maintenance required light 609thomasm YJ Wrangler Technical Forum 6 05-27-2009 07:53 AM
maintenance required light please help slmcook YJ Wrangler Technical Forum 10 02-26-2005 06:37 PM
Maintenance required light came on? DevilDogJeep YJ Wrangler Technical Forum 9 01-06-2005 11:34 PM
Help...maintenance required light a204600 YJ Wrangler Technical Forum 7 01-04-2005 02:25 PM
