maintenance required light - JeepForum.com
post #1 of 14 Old 02-04-2013, 02:47 PM Thread Starter
Exit93
What causes the maintenance required light to turn on?
Exit93 is offline
post #2 of 14 Old 02-04-2013, 03:03 PM
jeep63
jeep63's Avatar
Emissions timer.
You can replace it or pull the bulb.
jeep63 is offline
post #3 of 14 Old 02-04-2013, 03:06 PM
hypernoodle
I just removed the timer and the light hasn't come on since.
hypernoodle is offline
post #4 of 14 Old 02-04-2013, 03:25 PM
jbolty
jbolty's Avatar
This thing. Not sure if every year has it, but it just runs as a timer to tell you to spend money at the dealer every so often.
Not to be confused with the check engine light.
jbolty is offline
post #5 of 14 Old 02-04-2013, 03:49 PM
jokerchief462
Remove tie back wires throw away. Less parts less weight= more mpg. That is the only cheap fix you get with a YJ so cherish it.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 14 Old 02-04-2013, 03:52 PM
Old4X
1990 CJ7
Ah, there it is, the Master Reset Button. Activate that and everything defaults to factory specs, MPG jumps to max as well.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 14 Old 02-04-2013, 04:04 PM Thread Starter
Exit93
so if I remove it my MPGs will go up? Is that what your saying?
Exit93 is offline
post #8 of 14 Old 02-04-2013, 04:31 PM
jokerchief462
I say that lightly. It has no future purpose and it weighs less than a pond. Joking!!!! It has no effect other than the light and does not affect performance or send any signal to the ECU. 5k miles since I removed mine I needed to put my posi lock cable through the firewall and it was in the way. I had already removed the bulb.
post #9 of 14 Old 02-04-2013, 04:39 PM Thread Starter
Exit93
Do you have any tips on taking it out? Or pictures?
Exit93 is offline
post #10 of 14 Old 02-04-2013, 07:38 PM
Old4X
1990 CJ7
It is held in with screws, unscrew it, disconnect wire, done.
Old4X is offline
post #11 of 14 Old 02-04-2013, 08:47 PM
jbolty
jbolty's Avatar
It's usually located above the gas pedal and brake area
jbolty is offline
post #12 of 14 Old 02-04-2013, 09:37 PM Thread Starter
Exit93
And there's no negative effects that it will cause by removing it?
Exit93 is offline
post #13 of 14 Old 02-04-2013, 10:05 PM
hypernoodle
Not unless the maintenance required light being on is a positive.
post #14 of 14 Old 02-04-2013, 11:36 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
in simple terms, this was a timer put in at the dealership that only a dealership tech could reset that would get you to come in and replace exhaust parts and wear parts. It really wasnt needed. And there is not one single thing that is negative about removing it. Get rid of it.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
