Maintenance Req'd Light came on - JeepForum.com
post #1 of 14 Old 06-19-2002, 10:09 PM Thread Starter
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Uh oh, is what I said comin' home tonight. It came on, I checked the oil, and its low. I have been meaning to change it anyways. If low enough, which it was REALLY LOW. Would that most likely be the cause of the light? Can't seem to find any other problems.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #2 of 14 Old 06-19-2002, 11:11 PM
St.LJustin
St.LJustin's Avatar
Did the light turn off when you added the oil?
Black 95 4.0 YJ, RE Extreme Duty 4.5" with 33x12.5 BFG MTs and Much Much More
Member #5 of the Black Jeep Club
St.LJustin is offline
post #3 of 14 Old 06-19-2002, 11:31 PM
I-4
I-4's Avatar
did ya check the brake fluid? <img border="0" title="" alt="[Wink]" src="wink.gif" />
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #4 of 14 Old 06-20-2002, 06:53 AM
Prime Lord
Prime Lord's Avatar
Location: Chesapeake, VA (My office is just hell w/ florescent lighting)
Mine turned on out of the blue too...I was told it was a thing that the computer does every 20000 times you turn the ignition on. It dosen't mean anything is necisarily wrong, but Chrysler wants you to take it to the dealer anyway. Usually, they'll just replace the 02 sensor & maybe the catylitic converter...thats about it. However, taking it to the dealer is the only way to get the light turned off....& its re-damn-diculous too, my local dealer wanted $40 & 30 minutes of my life. I told the guy he was crazy & that I would just pull the bulb out.
~Jay
, 4.0, 5-speed. 1" Daystar Body Lift, 31x10.50 Goodyear MT/R's, CJ Style (87-91) Roll Bar, ARB Safari Snorkel, K&N Panel Filter, Dynomax SuperTurbo Catback. Still hunting for TJ Sahara flares!!!
, Maximum Motorsports: Rear LCA's, 4-point K-Member brace, & Std Length Subframe Connectors, FRPP 'C' Springs, Mac Pro-Chamber, Chrome BBK equal length shorties, B&M Ripper w/ leather cobra knob.
Prime Lord is offline
post #5 of 14 Old 06-20-2002, 08:36 AM Thread Starter
MusicMaverick
2014 JK Wrangler
I havent filled it yet. It happened 11pm last night. I will do it now, I hope it goes off. But I was REALLY low.
Currently: '14 JKU
post #6 of 14 Old 06-20-2002, 09:32 AM
gojurick
gojurick's Avatar
The Maint. Req'd light is different than the Check Engine light. It's sole purpose is to tell you it's time to change the O2 sensor. Change it yourself, takes about 5 minutes, then take it to a dealer to reset the light. A good dealer will do this for free in the driveway, as it will only take a few seconds.
'92 YJ, SOA w/ 35x12.5 X-terrains,RE quick-discs, Warn HS9500i, Detroit Electrac rear, ARB front, 4xDoctor rocker guards, AGR Steering, Borla Header & exhaust, Atlas II
Many bloody knuckles, Best of all, my wife luvs it too!!!
***Coming soon*** Chevy 350 V8 swap
gojurick is offline
post #7 of 14 Old 06-20-2002, 10:31 AM
Eryl Flynn
Why does every think it means change the O2 sensor? I have done this twice and neither time they changed the O2 sensor out.
It is a requirement by emsion laws that the O2 sensor be checked every so many miles, 70k is about the magic number but I am not sure. Dealer can check it, or any one with a diagnostic computer for Jeep vehicles. You can replace the O2 sensor, no biggie, hear they are cheap. Not needed most of the time.
Eryl Flynn is offline
post #8 of 14 Old 06-20-2002, 12:47 PM
LoOpY
change the oil. if its still there afterwards theres a really simple fix, cover the light with electrical tape!
LoOpY is offline
post #9 of 14 Old 06-20-2002, 02:05 PM Thread Starter
MusicMaverick
2014 JK Wrangler
The O2 sensor is on the front pipe right?
I don't like this idea that the light comes on every so many miles and needs to be reset by a dealer. Seems like its just another way to make $$. Its not fair. The Jeep is gettin' the oil changed right now, along with tranny and transfer case. Normally I'd do it myself, but we have these free oil change coupons we need to get rid of.
Currently: '14 JKU
post #10 of 14 Old 06-20-2002, 02:10 PM
gojurick
gojurick's Avatar
According to my repair guide, the light comes on every 82500 miles or so, so you shouldn't see it that often. It's just a mileage counter for a pre-determined number of miles that they think the O2 sensor should be replaced to maintain proper emissions. Some dealers with reset the light without showing proof of changing the sensor, mine made me show the receipt.
gojurick is offline
post #11 of 14 Old 06-21-2002, 07:37 PM
FLJeepGrrl
My maint. light came on just after I bought my Jeep. I was just starting to learn about working on my Jeep, and I took it to the dealer. They wanted $100 to replace it. (90 and earlier has to be replaced, can't be reset) I bought Chilton and found out what it was and took care of the problem myself. There's a little square smoke colored plastic box with some plastic gears in it attached to your firewall just above your gas pedal. That's the emis. maint. timer and that's the little jobby that turns your light on around 82500 miles. All that said, here are 3 simple steps to solving the problem. Remove 2 screws, unplug, and throw in garbage.
FLJeepGrrl is offline
post #12 of 14 Old 06-21-2002, 08:50 PM
JeepGuyRyan
The Maint Required light, like most have said, is a light that comes on after a certain amount of miles is placed on the vehicle. If you take it to a dealer, they will tell you that the light indicates that the timer needs to be replaced along with the O2 Sensor. If you take your Jeep in for a emissions test, most places will fail the vehicle if that light is on as it is part of the Emissions Control System (ECS) that light must be off, (not covered by tape as they do check for that stuff) with my expierence doing Emissions Testing (I/M 240 Dyne Test) most jeeps should have the 02 Sensor replaced every 80-100K miles. on 95% of the fuel injected jeeps that failed the emissions test, when they came back after having a new 02 sensor installed they passed with flying colors. The 02 sensor in most cases is rather simple to install yourself, and getting the sensor at Checkers will only cost you $30-50 depending on what type of sensor you have.
Hope this helped,
Ryan
-=Ryan=-
JeepGuyRyan is offline
post #13 of 14 Old 06-22-2002, 07:48 AM Thread Starter
MusicMaverick
2014 JK Wrangler
Well when they changed my oil they say that the light was on and reset it for $15. All set. Thanks guys
Currently: '14 JKU
post #14 of 14 Old 06-26-2002, 09:07 PM
NoSpin
This exact problem happened to me.The diagnosis...bad catylitic converter
92'Wrangler 4.0. 5sp.Rancho 2.5 suspension lift.Tuff country shocks.Alpine cd player w/thor sound wedges and soundbar.BFG 31.5x10 mud terrains.
steel horse rocker panels.
Rockcrusher acoustic safari brief.
NoSpin is offline
Is the "main't req'd" idiot light an emmissions thing? LandRover YJ Wrangler Technical Forum 7 08-23-2005 08:58 AM
maintenance light wranglerguy01 YJ Wrangler Technical Forum 1 05-02-2005 10:31 AM
turning off maint req'd light drewvw YJ Wrangler Technical Forum 9 11-10-2003 10:36 AM
Resetting "Man't Req'd" light? wsuspinster YJ Wrangler Technical Forum 10 12-02-2002 03:56 PM
Maintenance light on !!!!!! Help, Help ayadov YJ Wrangler Technical Forum 2 05-26-2002 08:10 PM
