maintenance replacement - JeepForum.com
post #1 of 5 Old 08-16-2013, 07:16 PM Thread Starter
chuck172
Our jeeps are can be 20 years plus. Is it smart to replace any parts befrore they go kaput? Ignition coil comes to mind. Is it smart to replace it before it craps out and leaves you stranded?
Or does it make more sense to not fix it till its broken.
chuck172 is offline
post #2 of 5 Old 08-16-2013, 08:35 PM
Rproject
1987 YJ Wrangler
Maintenance items are things like batteries, brakes, oil, coolant, plugs, wires, cap, rotor, etc. You don't replace a thermostat - starter - alternator - etc, just because. Those are more of "replace it when it breaks" type items.
So long as you do the regular maintenance, the other items will hold up longer.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 5 Old 08-16-2013, 08:54 PM
jokerchief462
Where do drive it??? If you are offroading like in NV up to 100 miles from a real road or town in area without cell service yeah there might be somethings you want to just replace or parts to carry with you.
You are going to have to make the decision as to what you want to replace and when usually dependent on $$$.
I spend about 30 minutes at least prior to going out and grease all and check all before I leave.
Really not a comprehensive list for you but you know your YJ better than anyone else so take care of it and do the normal maintenance. And then check it closely. If you are worried about breaking down the common items are u-joints, tie rod ends, shock mounts and stock D35s and all their components. Tune up parts are great to carry along with u-joints, and tie rod ends. Brake lines if you are really worried. This also includes any fluids you might need in a pinch when out.
Hope this helps I am just rambling here.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 5 Old 08-16-2013, 08:55 PM
bigbossd1030
X2
There is maintenance then there is a waste of time and money.
I get bugged every weekend by the family about working on my jeep all the time.
I have literally replaced 90% of the underside of my jeep. From driveshafts to radiator. Most I replace before a problem occurs. Mainly because I have no clue what the PO had done before I got it. But their vehicle will never see 303000km. So that makes me feel better.
But yes, replacing the coil wouldn't be a bad decision, as long as you haven't already replaced it soon before. Use common sense when wanting to replace parts. Like, should you drop the cash for a new starter when yours works just fine? No. Items like that you wait for, otherwise you will be spending a lot of money for nothing.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #5 of 5 Old 08-16-2013, 09:19 PM
SeanB95YJ
depending on the milage, might want to at least pull the timing cover and check the slop in the chain... and replace if the chain or gears look questionable.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
