Maintenance light on !!!!!! Help, Help - JeepForum.com
post #1 of 3 Old 05-26-2002, 01:25 PM Thread Starter
ayadov
Hi
I have jeep wrangler 1993 , the Maintenace light
came on about 3 month ago and never went off
this is not the check engine light, i try to unplug the battery but that didn't clear the light
any help or idea how to clear that light ?
Thank you
Arik
ayadov is offline
post #2 of 3 Old 05-26-2002, 07:27 PM
moabster
moabster's Avatar
2011 WK
From my Chilton's manual
"Emissions Maintenance Reminder Light"
The light comes on at about 82,500 miles and indicates the oxygen sensor and other related emmissions service is required...
The oxygen sensor and EMR are interdependent. When the reminder light illuminates, the oxygen sensor and EMR should be replaced simultaneously. This is important in ensuring proper engine performance. Maintenance reminders for 1991 (and later) vehicles are reset using a Diagnostic Readout Box (DRB).
Resetting or replacing the EMR without performing the required maintenance is a violation of federal law. Only after performing the required maintenance, should the EMR be reset.
Bottom line. The dealer can reset the light when He changes the oxygen sensor or you can replace it and show the dealer the old one and the new one installed and then the dealer can reset the light. I think the EMR module is only used on 1990 or older vehichles, the newer vehichles use the DRB.
If you are not inclined to perform the service you could always disconnect the light. <img border="0" title="" alt="[Wink]" src="wink.gif" />
HTH
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #3 of 3 Old 05-26-2002, 08:10 PM Thread Starter
ayadov
Thank you
I will have that checked later next week at the
Dealer, I use to have the book also but I can't
find it, I am still looking, do you have idea for
how much that may cost to replace that ?
Thanks for the tip
Arik
ayadov is offline
maintenance required light onlyjeep YJ Wrangler Technical Forum 18 09-19-2009 07:46 PM
maintenance light wranglerguy01 YJ Wrangler Technical Forum 1 05-02-2005 10:31 AM
Maintenance required light came on? DevilDogJeep YJ Wrangler Technical Forum 9 01-06-2005 11:34 PM
Help...maintenance required light a204600 YJ Wrangler Technical Forum 7 01-04-2005 02:25 PM
Maintenance Req'd Light came on MusicMaverick YJ Wrangler Technical Forum 13 06-26-2002 09:07 PM
