Maint. Required Light ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Maint. Required Light ?
HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff XJ Unirail Channel Reinforcement....
Unread 06-06-2007, 04:19 PM   #1
dave_dj1
as the proud new owner of a 91 wrangler, at first i thought it was the same as check engine light but it's not, any idea what makes this light stay on? i have checked everything i can think of??????and how do i shut it off short of removing the buld?
thanks,
dave
dave_dj1 is offline   Reply With Quote
Unread 06-06-2007, 04:45 PM   #2
YJ-Mike
I don't know for sure on that model, but many times manufacturers put in something like that to let you know that a certain number of miles have gone by and that it is time to do something.
Found this with a quick google:
Long Answer: On the Wrangler the "Maintenance Required" light is triggered by a timer function and is not associated with a particular fault. Most people associate it with the scheduled replacement of the O2 sensor. The "Check Engine" light is the more serious and is associated with some sort of discrepancy. The "Check Engine" light can be reset by disconnecting the negative battery terminal but don't do so before retrieving the fault codes stored in the computer. You can find the procedures and diagnostic code meanings at http://minimopar.knizefamily.net/
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here: http://www.jeepforum.com/forum/f12/yj-build-plan-259306/
YJ-Mike is offline   Reply With Quote
Unread 06-06-2007, 04:48 PM   #3
mp3coupe
91 should be fuel injected, computer. The carb engines had a gray box near the gas pedal. I know my 90 had one, I would think they did away with that on F.I models.
Look by your gas pedal for a clear grayish box and unplug it. It will have gears inside of it......
here you go, search works awesome
http://www.jeepforum.com/forum/showt...Maint+Required
the 2nd post, a link to what it looks like it.
mp3coupe is offline   Reply With Quote
Unread 06-06-2007, 05:11 PM   #4
dave_dj1
wow, that made for some interesting reading, i would have searched but i've come to the conclusion we all like to share our knowledge on a more personal level.....lol......
so? will the scanner that they use to scan for you at advance auto reset it or will i have to buy one? i don't know anyone who has one handy.
thanks for the great links and info and quick responses,
dave
Unread 06-06-2007, 05:40 PM   #5
GrimJeeper91
The maintenance req'd light cannot be reset. The timer must be replaced or the bulb pulled. Since I couldn't find the timer pictured in the linked post I ended up pulling the bulb.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline   Reply With Quote
Unread 06-06-2007, 05:42 PM   #6
mp3coupe
dave
I didn't see a reset on mine. If it were mine I would just unplug it and the light will go out. I think those units are a one time deal but I'm not 100% sure. If it's a one shot deal I wouldn't waste money on it. I would however replace the o2 sensor, they do age and act up. The O2 is a key piece to F.I engines. --think gas milage
Unread 06-06-2007, 06:34 PM   #7
kloppk
Up thru 1990 the Wranglers had a mechanical timer that controlled that light.
The timer is a plastic box attached to the firewall up and to the right of the gas pedal. This timer box is not resettable. It has to be replaced (or disconnected) to make the light go out. It was meant to be replaced when you replaced the O2 sensor.
In 1991 they eliminated the mechanical timer box and the light is now turned on & off by the ECU computer.
kloppk is offline   Reply With Quote
