Maint Reqd?? - JeepForum.com
post #1 of 13 Old 04-26-2008, 04:06 PM Thread Starter
PFP
Maint Reqd??
Does anyone know of a way to turn off the Maint Reqd Light on a 91 YJ, other than removing the bulb??
THanks
PFP is offline
post #2 of 13 Old 04-26-2008, 04:22 PM
dave_dj1
that friggin light means nothing , it's not the same as the check engine light, i just pulled the bulb, problem solved! forever
Wheel it like ya stole it!
dave_dj1 is offline
post #3 of 13 Old 04-26-2008, 06:04 PM
djfred
I was told that light comes on ~80K miles and is a gimmick from the stealership. So you end up taking your car to them and having them look at it and charge you and arm and a leg for something really cheap. Mine is on and i don't even pay attention.
No way to turn it off unless you take it to them
--Now--
White 92 YJ -- RE 1.5" SOA -- BFG KM2 35x12.50x15 -- D30 (4.88 w/ ARB) -- Ford 8.8 (4.88 w/ ARB)
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #4 of 13 Old 04-26-2008, 06:16 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Look under the dash down on the fire wall just to the right of the gas pedal. There is a small clear box mounted to the fire wall. Take it off or just unplug the wires going to it.
ALL THIS LIGHT IS USED FOR IS TO TELL YOU WHEN YOU NEED TO TAKE IT BACK TO THE DEALERSHIP TO REPLACE THE EXAUST or some other stupid part and then pay $40 bones to have them "reset" it (wind it back/repace it)
Just remove it. Dont bother with the light. Also, I could be off on my years, I do not know when the took that little stupid box out.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 13 Old 04-26-2008, 07:15 PM
GrimJeeper91
GrimJeeper91's Avatar
It's my understanding that this box (pictured below), isn't on the 91's. It wasn't on mine. I ended up pulling my bulb because when I checked the codes nothing out of the ordinary came up.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #6 of 13 Old 04-26-2008, 07:23 PM
kloppk
Correct.
This timer box gizmo was only used on the 6 cyl 4.2's which were only used thru model year 1990.
kloppk is offline
post #7 of 13 Old 04-26-2008, 07:32 PM
Exparrot
Exparrot's Avatar
Got confused, so I deleted my previous post. My '93 doesn't have one, or if it does, the Jeep gods did me a favor and burned the bulb out for me already!
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #8 of 13 Old 04-26-2008, 07:34 PM
rustywrangler
Ok so I was wrong, does the computer control the "maint" light after 91, or is there something else that is involved??
post #9 of 13 Old 04-26-2008, 07:46 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
OP, what exactly is the problem with pulling the bulb???
hhhmmmmmmm lemme think, spend hours looking for a "solution", or just yank the bulb out and keep as a spare in @5 minutes..... i must be lazy i guess
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #10 of 13 Old 04-26-2008, 07:47 PM Thread Starter
PFP
The book (manual) indicates that it is timer, but was told that the dealer had to reset. I will look to see if I have one of those boxes, but don't think so since it is a 91 with 4.0L. I did remove the bulb, but would like to turn it off and return the bulb.
PFP is offline
post #11 of 13 Old 04-26-2008, 07:57 PM
kloppk
Yup - Starting in 1991 the Maint Reqd light is controlled by the ECM.
kloppk is offline
post #12 of 13 Old 04-26-2008, 11:41 PM
Fif28
Any shop with a scanner can reset the light. If the shop has an OTC or Snap-on scanner that will work just fine. I used to charge a standard $25 to turn them off. I haven't seen one on in years.
Fif28 is offline
post #13 of 13 Old 04-27-2008, 02:27 AM
idaholtby
The "maintenance required" lamp is nothing more than a timer to indicate that the user should replace the O2 sensor. OBD1 equipped jeeps where set up to replace the O2 sensor on a timed PM rather then have them fail undetected. Just replace the O2 sensor and remove the lamp. Or replace the sensor and bring it into the stealership to reset the lamp. Your choice.
idaholtby is offline
maint reqd light trimental43 YJ Wrangler Technical Forum 4 01-17-2008 04:59 PM
anyone know how to get rid of maint. reqd. light in a 92yj? YJRomeo YJ Wrangler Technical Forum 24 12-27-2007 01:35 PM
I have a BB, whats reqd for a BL? jbpdog TJ Wrangler Technical Forum 1 07-02-2006 06:28 PM
1992 jeep wrangler maint.reqd. light bohunk YJ Wrangler Technical Forum 5 11-14-2005 11:19 AM
How do you turn off the Maint Reqd Light? Antelope YJ Wrangler Technical Forum 6 11-15-2004 10:34 AM
