magnetic antenna mount - JeepForum.com
post #1 of 6 Old 07-18-2007, 01:08 PM Thread Starter
mysterymachine
The wife has a 1993 Wrangler that is basically stock. She has back conditions so she is reluctant to raise it at this time. I will be taking the Wrangler to Camp Jeep next week and have temporarily installed a CB radio so that I can communicate with all my buds. I am looking for a quick build antenna mount to temporarily hold a magnetic mount antenna. ( I know, old school technology - but everything I am using has been provided to me free.) I am thinking about trying to mount the antenna to the spare tire mounts on the tailgate. Has anyone made a homemade bracket like this and be willing to share how it was made? I will need to build it in my garage. I have limited tools and no ability to weld.
I am new to postings but have been reading over them for several weeks. We are a three jeep family. We share a 93 Wrangler, a 96 Cherokee and my work vehicle is a 2006 Liberty.
mysterymachine is offline
post #2 of 6 Old 07-18-2007, 01:15 PM
MMerrick
i have tried the rear tires mount as well...doesnt work if you plan on keeping the spare tires of there...with the magnetic i just put it behind my rear seat and cut aroudn the carpeting untill i was able to get another antenna
1995 Green YJ
- Cobra CB/PA System
- 64" CB Antenna Whip, tailgate stop mounted
- 3.5" Superlift Lift Kit w/ Teraflex 9000 SSV Shocks
- 31"x11.5" Interco Super Swamper LTB Bias Tires
- Cragar 342 Black D-Window 15x8 wheels.
MMerrick is offline
post #3 of 6 Old 07-18-2007, 02:18 PM
claybob
claybob's Avatar
If it's magnetic I would just stick it on the cowl right behind the hood.
04 LJ, 4" RC Susp Lift, 35x12.50 Mickey Thompson Baja Claws
claybob is offline
post #4 of 6 Old 07-18-2007, 05:56 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
If you mount it anywhere on the hood or front fenders, and are driving through low trees, you will scratch the paint. I know this from experience. Your wife may not appreciate trail scars like we do. If your are going topless, try what MMerrick suggests, or one of the rear wheel wells might work better. If your not topless, you could lose that plastic "JEEP" frame cover up front and use the frame for the trip.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #5 of 6 Old 07-18-2007, 06:16 PM Thread Starter
mysterymachine
MR B is right. My wife wouldn't appreciate the trail scars. I had originally considered putting it on the right front fender but figured it wouldn't last long there. I got my 13 yoa son in on the project and we have fabbed up a bracket that we hope will fit onto the top bolts of the spare tire mount. We made it come up behind the spare and then it angles out above the spare like a shelf. We didn;t get to finish tonight. Hopefully we can get back to it tomorrow evening and road test it.
post #6 of 6 Old 07-20-2007, 11:58 AM
schizm99
take a small peice of metal and bend it drill holes and mount to the rear carrier.. be sure the edges are ground down!! I have mine on the rear wheel wheel but have used that set up before
schizm99 is offline
Opinion on Antenna Mount / Antenna HammerG26 JK Wrangler Technical Forum 22 01-04-2011 06:49 PM
cb magnetic antenna mount flexsaharatj TJ Wrangler Technical Forum 8 10-11-2009 05:34 PM
capping antenna mount when antenna is off Jeeper-4-Life TJ Wrangler Technical Forum 0 02-10-2007 08:57 PM
Your CB antenna mount LOCKED UP YJ Wrangler Technical Forum 22 09-30-2006 10:59 PM
CB Antenna Mount bondo303 TJ Wrangler Technical Forum 2 06-29-2004 01:08 PM
