lunch box locker spring set - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > lunch box locker spring set
8.8 Swap Kit w/ TRUSS for JeepsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-26-2015, 08:34 PM   #1
1tuffchevy
I was given an old Detroit E-Z lunch box locker for my dana 30 however the springs are a little messed up in it. Does anybody know if new spring sets are available for it or if a spring set off of another brand would work? can't seem to find any info
thanks
Zack
1tuffchevy is offline   Reply With Quote Quick reply to this message
Unread 02-26-2015, 08:59 PM   #2
timatoe
timatoe's Avatar
I'd try THESE GUYS.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 02-26-2015, 10:16 PM   #3
1tuffchevy
nothin
Unread 02-27-2015, 02:20 PM   #4
Schaef81
Have you tried contacting Eaton?
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 03:14 PM   #5
pete1991YJ
Go to McMaster-Carr. They will have something that will fit. They are an industrial supplier. http://www.mcmaster.com
Scroll down till you see "springs".
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
