LT1 Be Cool Radiator - JeepForum.com
post #1 of 11 Old 06-05-2007, 04:50 PM Thread Starter
greatyanks23
Is there another (cheaper) solution for a radiator for a LT1 in a 90' YJ? I was looking at the "Be Cool" radiator on Quadratec's website ($869.99). Any other suggestions would be appreciated. I am going to run a 740R4/NP231C setup with the LT1.
http://www.quadratec.com/products/51210_602.htm
This is the link to the "Be Cool" setup
Thanks,
Chris
greatyanks23 is offline
post #2 of 11 Old 06-05-2007, 06:02 PM
ScotZ
American to the Bone
ScotZ's Avatar
This "might" help
http://cgi.ebay.com/ebaymotors/NEW-H...QQcmdZViewItem
http://www.tellico4x4.com/index.php/...91a8f7aa41b639
http://www.lt1tech.com/ These guys will know. Just ask.
$869.99 is bloody ridiculous
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline
post #3 of 11 Old 06-05-2007, 06:11 PM
ScotZ
ScotZ's Avatar
This is a great thread if you are thinking about a swap. He did a TJ but it is very good.
http://www.jeepforum.com/forum/f7/my-v8-swap-blog-updates-365293/
- Aldous Huxley
ScotZ is offline
post #4 of 11 Old 06-05-2007, 07:45 PM
1 ton yj
1 ton yj's Avatar
One of these days I'm going to get a TIG so I can get filthy rich welding a couple tabs to the side of a universal dirt track radiator and sell them as a conversion radiator for twice what they are worth.
Seriously, get a $200 Chevy universal 22x19 aluminum radiator from Summit or Jeg's and make your own mounts with scrap steel. It's very simple. Here is my radiator with Taurus fan. I have about $300 in my entire cooling system including radiator hoses and wiring for the fan.
I wheel it like I stole it and it has never gotten over 210 with this setup.
1 ton yj is offline
post #5 of 11 Old 06-05-2007, 09:12 PM
sgtcherokee
I had the same Radiator in my last rig only I mounted it in the rear , never got hot unless I forgot to turn on the fan I was running a 350 as well.
94 YJ , comp cut , 8.8 , 102" WB , XJ rear springs , and a few other things here and there
sgtcherokee is offline
post #6 of 11 Old 06-05-2007, 09:21 PM
1 ton yj
1 ton yj's Avatar
That's why I porpusely left the switch out of the fan circuit! I let the ECM decide when the fan is on and off! I go around deep water/mud anyway, that stuff does too much damage.
1 ton yj is offline
post #7 of 11 Old 06-06-2007, 12:38 PM
Don-T
Until recently I had an Extreme Radiator heavy duty conversion with the stock jeep shroud and fan run off the water pump. It was marginal in cooling. If I let it idle for very long the temp would creep up and if I went over 70 MPH the temp would creep up. One of the mounts on the radiator (epoxied to the tanks) failed. I decided to get a Be-Cool radiator because I have used them in the past with good luck. I bought the radiator from Summit Racing, I thing their pricing is better. I bought the version without the trans cooler built in, and then I bought a Hayden cooler for the trans. I am now using an electric fan from Summit too. The cooling is far better now. I have not been able to get the temp over 200*. I am running this with a 350 TBI and 700R4.
12 Rubicon
Don-T is offline
post #8 of 11 Old 06-06-2007, 01:33 PM
gimme mud!
this place sells the radiator for 199$ http://www.xtremeterrain.com/p86.htm
gimme mud! is offline
post #9 of 11 Old 06-06-2007, 01:33 PM
1 ton yj
1 ton yj's Avatar
Could it be because you now have the trans cooler seperate like it should be? My dad has an 86 S10 backhalfed with a narrowed 9" and 18" slicks powered by a hot (no pun intended) SBC roller motor. We chased an overheating issue all over and finally out of a guess one day I bypassed the trans cooler in his radiator and the temp dropped 15 degrees! He now has the same B&M fan-cooler I have in the bed of the truck.
I never understood the reason behind combining the two coolers. Automatic transmissions operate at a much lower temperature range (160-180) than an engine does (190-21) so in effect you are actually heating your trans if it is connected to the radiator. Not to mention the mess that follows if the unit fails and oil mixes with coolant.
1 ton yj is offline
post #10 of 11 Old 06-06-2007, 01:57 PM
Don-T
The previous radiator had the trans cooler in the bottom tank. I have checked the temperature of the trans lines and the supply was at 175* and the return was at 170*. I think that means I was getting some cooling from it but I think the trans should be cooler than that. One of these days I will check the trans cooler to see how it is doing now. The big reason I got away from the other manufacturer is because the mounting bracket failed. The new one is all welded aluminum, I don't think it will come apart. I suspect this radiator may be more inefficient because the electric fan pulls less air then the mechanical fan did at idle but the temperatures are about 15* cooler. The difference is more under load.
12 Rubicon
Don-T is offline
post #11 of 11 Old 06-25-2010, 10:29 AM
spark plug
Summit radiator $158 Taurus fan $35 autozone wire kit $40
"93" YJ 3.5 BDS, 5/8" Boomerings, 1"BL
33"x12.5" Ford 5.0 8.8 AX-15 231 SYE
spark plug is offline
Be Cool radiator for 04 Rubi NC4stroker TJ Wrangler Technical Forum 16 02-28-2016 10:04 AM
Tire Covers ? Cool or Not Cool ? tire_smoke Wrangler General Discussion 58 04-24-2012 12:38 AM
lower radiator hose cool???? RebuildRookie YJ Wrangler Technical Forum 6 11-24-2009 07:00 AM
Be Cool Radiator and Clutch Fan??? soulknight TJ Wrangler Technical Forum 1 07-09-2009 05:50 AM
89 yj radiator hot on top cool on bottom Stemme YJ Wrangler Technical Forum 1 02-07-2009 03:01 PM
