Lower steering shaft bearing replacement - With pics! - Page 6 - JeepForum.com
post #76 of 92 Old 04-21-2013, 05:37 PM
catnip15
Reviving an old thread, I have a 02 TJ, I have a slight "pop" coming from the steering and a little bit of wobble in te from end when I get up to speed. I had a friend move the wheel back and forth while I looked for play in the suspension, found that the steering shaft where it connects into the steering gear box is popping. Does this mean I need to change that bearing/seal? I looks like it is leaking a small amount of fluid.
Other than that there is no whining and the steering isnt difficult to turn.
catnip15 is offline
post #77 of 92 Old 04-22-2013, 10:03 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Seems to me you need to have your steering box overhauled or replace the seals. Specially if there is fluid leaking, the bearing is at the top of the shaft near the firewall, however if you do remove the shaft it may be a good opportunity to change the bearing as well. Good luck!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #78 of 92 Old 08-24-2013, 11:29 AM
tggraham
cheapest I found
in case anyone is currently looking for this part
http://www.ebay.com/itm/221229582330...S:1120&vxp=mtr
tggraham is offline
post #79 of 92 Old 05-04-2014, 08:22 PM
pointech
2014 JK Wrangler
I've had these instructions and my new bearing sitting on my workbench for at least a year now. I finally did the install today. Thanks a bunch for this write up with pictures - it was very helpful!
pointech - Tom in Virginia
2014 Wrangler Sport
SOLD 1994 Wrangler YJ S - 4 cylinder 5 speed -
SOLD 1997 Jeep Wrangler TJ SE
pointech is offline
post #80 of 92 Old 05-05-2014, 09:43 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
You're welcome!
Fernando is offline
post #81 of 92 Old 05-23-2014, 10:26 AM
YJMCB
1987 YJ Wrangler
Thanks Fernando for the great write-up,changed mine this morning.You made it a simple job by reading your write-up.I did not have an extra set of hands so I had to build me i little platform to move the steering box.thanks again,yjmcb
87 YJ,SOA,35-12.50 Mickey Thompson Claws 92 XJ,8.8 detroit rear,35's & other stuff.
YJMCB is offline
post #82 of 92 Old 05-29-2014, 03:43 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
You're very welcome!
Fernando is offline
post #83 of 92 Old 06-16-2014, 06:26 AM
ziloh22
Great write up !
2012- Gecko JK Rubicon Unlimited- building...
2007 JK Rubicon Unlimited- 3.5 RK X Factor 37s-SOLD
1995 Gecko YJ with a TJ Front- 35s
ziloh22 is offline
post #84 of 92 Old 11-19-2015, 10:51 AM
ericp2011
Thanks a lot
After replacing the gearbox twice, changing all tie-rods, changed the power and more, all I had left to change was the lower steering shaft (I believed) until I read your thread.
Ordered the $25.00 part, replaced it, and my 95 Jeep steers like new now!!!
So before you start playing with the gearbox adjustment screw, just check this bearing and it might save you a lot of money, trust me!
My old plastic retainer was cracked and the bearing was loose, followed the easy instructions on this write up and back to Jeeping!!!!
ericp2011 is offline
post #85 of 92 Old 11-19-2015, 12:38 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Awesome! I'm glad this thread helped so many, such a small part is easy to overlook.
Fernando is offline
post #86 of 92 Old 04-28-2016, 01:21 PM
galby81
Smooth sailing up until the point of the bearing not wanting to come off, it is spinning but still being held on by what I am hoping to be just remaining pieces from the bearing. Hopefully a dremel sorts this out. I am assuming that all YJs from 87-95 have smooth ends and not some permanent fixture put on later to hold the bearing in? Mine is a 95. Anyways, off to get a dremel to give that a try.
galby81 is offline
post #87 of 92 Old 04-28-2016, 01:39 PM
dancytron
I was able to grab mine with a little vice grips and just tear it off.
dancytron is offline
post #88 of 92 Old 04-28-2016, 02:47 PM
galby81
Was prying a bit with mine, but seemed as though I was gonna wreck something so hitting up the dremel as soon as I finish up supper and will post how she goes.
galby81 is offline
post #89 of 92 Old 04-28-2016, 03:27 PM
galby81
Got it! Dremel worked liked a dream, the bearing was pretty near welded to the shaft. Now to throw er in and see how that goes.
galby81 is offline
post #90 of 92 Old 04-28-2016, 05:19 PM
galby81
Bearing in! Had to tap the back of a socket with a hammer, not hard though to get it to go, thanks for the write up.
galby81 is offline
Lower Steering shaft replacement EnFuegoUno YJ Wrangler Technical Forum 14 10-24-2009 07:15 AM
Lower Intermediate Steering Shaft Pics cntryboy JK Wrangler Technical Forum 0 05-20-2009 10:43 AM
Steering Shaft and Bearing Replacement ech0sh4y YJ Wrangler Technical Forum 6 11-18-2008 09:09 PM
steering column lower bearing replacement azgurney YJ Wrangler Technical Forum 10 03-18-2008 06:12 PM
how to replace lower steering shaft & bearing??? raStapiMpjaY YJ Wrangler Technical Forum 0 04-02-2006 01:51 PM
