Lower steering shaft bearing replacement - With pics! - Page 5 - JeepForum.com
post #61 of 92 Old 04-29-2012, 07:17 AM
rich490
Thanks for the write up. I was able to do mine yesterday in a little over an hour. Just a lot of PB Blaster and I was able to get the whole thing apart.
rich490 is offline
post #62 of 92 Old 05-10-2012, 08:32 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Glad I could help!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #63 of 92 Old 05-15-2012, 11:32 PM
Jeepluvr38
1983 CJ7
Question about the old lower column bearing...
Hi folks - I'm new here, just joined when I picked up an 83' CJ7. The lower column bearing went out on me last week, and I purchased the bearing kit and have removed everything and I'm ready to reassemble but the new bearing doesn't seem to want to fit on the column shaft.
Is it common for the inside race of the old bearing to remain on the shaft, just above the splines? Is the shaft supposed to be totally smooth above the splines? I can cut it with a whiz wheel or dremel, but don't want to do any unnecessary damage. Any help would be greatly appreciated.
Thanks!
Chris
Jeepluvr38 is offline
post #64 of 92 Old 05-16-2012, 07:14 AM
Que89YJ
LOL You are in the YJ section. You should be posting up to the CJ! Welcome to the forum. You have the same basic setup as us so when I did mine the bearing race did stick to the shaft and I did use the dremel to score it and break it fee. I didn't go all the way through because I was worried about messing up the shaft. I had a difficult time getting it back on too. I sanded the shaft to smooth it. Cleaned it up and greased it.
Que89YJ is offline
post #65 of 92 Old 05-16-2012, 08:59 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Mmmmm I didn't experience any problems like this... Mine came out smooth. I guess use whatever means necessary to remove the old bearing but take care not to damage the shaft... Good luck!
Fernando is offline
post #66 of 92 Old 05-17-2012, 03:28 AM
mudsweatNgearz
1987 YJ Wrangler
Here ya go.....to your door for under $15......mine will be here tomorrow
http://www.ebay.com/itm/380433655078...84.m1497.l2649
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #67 of 92 Old 09-01-2012, 11:46 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Some user asked me this question, but his inbox is full and I'm unable to reply so I'm answering his question here
Originally Posted by 77cj7Jeep
on the write up you did on the lower steering shaft bearing. when you snap the bearing in the white plastic bushing my bearing spins in the plastic bushing and is a little loose. Should it be that way?
Thanks
Mmmmm that's strange, the fit is not super tight but shouldn't be loose either... Can you send me a pic of the assembly?
Fernando is offline
post #68 of 92 Old 09-01-2012, 03:37 PM
jokerchief462
Great writeup and the link to Ebay works. Just checked mine very loose. I am about to start the tear down and fix all the front end steering so great start at the right place. Just hoping the gearbox is still good just needs an adjustment. THANKS for a great write-up.
jokerchief462 is offline
post #69 of 92 Old 09-02-2012, 10:03 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
You're very welcome! Hope yours goes smooth!
Fernando is offline
post #70 of 92 Old 09-12-2012, 07:57 PM
GilNewJeeper
2008 KK Liberty
Hey Fernando, I'm in the process to replace my steering box with a re-built 1999/Durango (hear they are stronger than the YJ). Just replaced my steering shaft and stabilizer but had too much play and when going out of a highway ramp (circle) the front end is all over the place. Is this bearing at the steering box/shaft connection?. The re-built one will come with a new bearing, right?...Thanks
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #71 of 92 Old 09-12-2012, 11:18 PM
jokerchief462
Out & in no issues and what (bearing) I took out was junk. Tightened things up quite a bit now on to the ball joints and tie rod ends. Thanks for the great write-up.
post #72 of 92 Old 09-13-2012, 05:59 AM
Que89YJ
Gil, if it is rebuilt it should include a new bearing.
Que89YJ is offline
post #73 of 92 Old 09-14-2012, 12:18 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
sorry Gil I was away on business and could not respond earlier... Mmm the steering bearing will prevent vibrations at the steering wheel and dash, but if your steering wanders then you have another problem... what exactly do you mean when you say "the front end is all over the place" ?
Thank you I'm very glad it was useful for you!
Fernando is offline
post #74 of 92 Old 09-14-2012, 04:15 PM
GilNewJeeper
2008 KK Liberty
Well, it is like the car is going to the right but the tires want to go to the left. I just replaced the gear box today and is a lot better but I think I need an alignment and tire rotation. I also think that I need to replace the sway bar bushings. All this will be done soon.
2008 Jeep Liberty
post #75 of 92 Old 09-29-2012, 05:50 AM
YJames90
YJames90's Avatar
Found this today. Guess what im doing?
My 2.5 to 4.3 swap thread
YJames90 is offline
Lower Steering shaft replacement EnFuegoUno YJ Wrangler Technical Forum 14 10-24-2009 07:15 AM
Lower Intermediate Steering Shaft Pics cntryboy JK Wrangler Technical Forum 0 05-20-2009 10:43 AM
Steering Shaft and Bearing Replacement ech0sh4y YJ Wrangler Technical Forum 6 11-18-2008 09:09 PM
steering column lower bearing replacement azgurney YJ Wrangler Technical Forum 10 03-18-2008 06:12 PM
how to replace lower steering shaft & bearing??? raStapiMpjaY YJ Wrangler Technical Forum 0 04-02-2006 01:51 PM
