Lower steering shaft bearing replacement - With pics! - Page 4 - JeepForum.com
post #46 of 92 Old 08-08-2010, 08:00 PM
zacharydruhm
Just wondering if changing this bearing would affect the alignment at all? Great write up.
zacharydruhm is offline
post #47 of 92 Old 08-09-2010, 12:59 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
It did not affect it on mine... I don't think it will!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #48 of 92 Old 08-16-2010, 06:57 PM
jbolty
jbolty's Avatar
Thanks for the pictures and write up.
I just did mine yesterday. First, here is the cheapest place I found for the bearing.
EDIT:
removed the link. Oconee offroad has an amazon store with a really cheap price for the bearing, but the link keeps changing. Search for it; it's only $19
Second. Mine came apart in pieces and I had to dremel the inner race out so I had to guess a little putting it back together. It seems that the plastic spacer goes in first, then the bearing snaps into that, small end first, then the metal cup goes on. But doing it that way there is really nothing holding the bearing in place other than the teeny plastic snap and friction from the steering shaft. Or, did I not get all the pieces out of mine?
Any one else have a fallen apart bearing?
thx
BTW. It's not needed to take the steering box out IF the telescoping part of the shaft will move. On mine I was able to clamp some vice grips on the upper part of the shaft and use that surface to tap down.
jbolty is offline
post #49 of 92 Old 08-16-2010, 08:09 PM
jyoukhanna0218
Something looks completely wrong in that first picture. Where in the hell is the rust that should be covering the frame? Is costa rica some sort of magical land where jeeps last forever?
jyoukhanna0218 is offline
post #50 of 92 Old 10-07-2010, 08:53 PM
twildt
1978 CJ5
i have a 78 jeep cj5, i have my steering shaft off, im trying to get the lower column bearing off to replace it and i have bent the crap out of the steel casing around the bearing and its plastic housing trying to slide it off the column shaft but its so rusted and there's no room to get a hammer and pry bar in there.... how do i get that old rusty bearing off the lower steering column shaft??? HELP!!
twildt is offline
post #51 of 92 Old 10-08-2010, 05:08 AM
Louie4
Have you tried prying the metal housing the bearing goes into apart? I recently helped my buddy replace his on his '81 CJ-7. If that doesn't work you could try a slide hammer but it might be too big.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #52 of 92 Old 10-08-2010, 09:16 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Do they use the same bearing? I've never seen a 78 CJ5 so I wonder... removing that clip was fairly easy, but then again, no rust on mine.
Fernando is offline
post #53 of 92 Old 10-08-2010, 03:53 PM
twildt
1978 CJ5
Fernando mine is the exact same as yours, clip came off easy but i can't get the bearing to slide off. I didn't see the posts on your 1st page of this forum post where some of the guys took the column loose and lifted it out a little or the shaft slid down, either way i will try that and see if i can get to the bearing.
i will post my results.
twildt is offline
post #54 of 92 Old 10-09-2010, 07:27 AM
jbolty
jbolty's Avatar
Mine was so rusted the outer part of the bearing fell off but I had to cut the inner race with a dremel.
jbolty is offline
post #55 of 92 Old 02-04-2011, 09:46 PM
Tompatt
1987 YJ Wrangler
this is a great write-up. but heres a question. i have heard to torque the bolt that holds the steering shaft to the joint to 33ft/lbs. is 33 wrong and 65ft/lbs right?
Thomas
-1987 YJ
Tompatt is offline
post #56 of 92 Old 07-15-2011, 02:39 PM
danlee
1987 YJ Wrangler
I am going to try this repair this weekend, I was thinking of using a ratchet strap to get my steering shaft to draw in. Anyone ever done this?
danlee is offline
post #57 of 92 Old 07-15-2011, 04:28 PM
dancytron
I've been told by 2 different professionals the lower steering shaft (if it is stock) is not made to collapse except in a crash. It has a metal clip inside it or a plastic shear pin that you are breaking if you get it to collapse.
Lower the steering box like the OP says.
dancytron is offline
post #58 of 92 Old 07-15-2011, 04:55 PM
jbolty
jbolty's Avatar
Sounds like bad information. If you order a new one it comes collapsed and will move pretty easy until it rusts up.
jbolty is offline
post #59 of 92 Old 07-16-2011, 06:57 AM
danlee
1987 YJ Wrangler
Bearing replacement
I noticed mine has a shear pin in it as well, I ended up pulling the steering box, after that it went real easy
danlee is offline
post #60 of 92 Old 07-18-2011, 11:09 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
I'm sorry I have not been following my own post, I see a lot of comments I haven't read till today... the 33 ft/lb value is for the shaft bolt, the 65ft/lb value is for the bolts holding the steering box to the frame... I think if you try to apply 65ft/lb to the shaft bolt it will either break or strip.
For those of you who have rust on your shaft or box, it may help to apply PB Blaster to everything, everyday, for at least a week before attempting the job... Mine has no rust because of Costa Rica's weather and the area where I live, plus I try to take good care of the frame.
Fernando is offline
Lower Steering shaft replacement EnFuegoUno YJ Wrangler Technical Forum 14 10-24-2009 07:15 AM
Lower Intermediate Steering Shaft Pics cntryboy JK Wrangler Technical Forum 0 05-20-2009 10:43 AM
Steering Shaft and Bearing Replacement ech0sh4y YJ Wrangler Technical Forum 6 11-18-2008 09:09 PM
steering column lower bearing replacement azgurney YJ Wrangler Technical Forum 10 03-18-2008 06:12 PM
how to replace lower steering shaft & bearing??? raStapiMpjaY YJ Wrangler Technical Forum 0 04-02-2006 01:51 PM
