Lower steering shaft bearing replacement - With pics! - Page 3 - JeepForum.com
post #31 of 92 Old 03-26-2010, 01:00 PM
JW-YJ
Steering box. The lower end of the steering column just underneath the front bumper.
JW-YJ is offline
post #32 of 92 Old 03-26-2010, 01:09 PM
Louie4
"You pass butter"
Louie4's Avatar
In that case then I concur with Opihi59. The sealed steering box might of had a seal go bad. The only other thing that it "might" be is brake fluid. There is a brake line that goes around the bottom of the grill to cool I guess. Anyway, I know my YJ has it, maybe yours does too. Just from what you described clearish liquid. But you would of had brake problems and I'm not sure what color the fluid is in a non-power steering box.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #33 of 92 Old 03-26-2010, 04:26 PM
JW-YJ
So guys, now that I had a second to take a look at the ride. It DOES have power steering... It IS leaking from the lower steering box. I knew some of these Jeeps don't have power steering so didn't think a thing of it until I really got a look at the engine. So I filled it up again, and wow that's a lot easier to drive.
I'm not sure if it's a gasket or a damaged bearing, it's leaking from the bottom of the steering box where the steering arm connects.
JW-YJ is offline
post #34 of 92 Old 03-26-2010, 07:11 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
I was wondering about a 95 without power steering, I have actually never seen a YJ without power steering
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #35 of 92 Old 03-31-2010, 04:48 PM
bhartwell59
1987 YJ Wrangler
does the intermediate shaft telescope down? looks like it would.
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #36 of 92 Old 03-31-2010, 04:54 PM
Hussler
1992 XJ Cherokee
An 87??? That looks like the underneith of an 06 tj in NY! I wanna move to costa rica
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #37 of 92 Old 03-31-2010, 10:12 PM
JW-YJ
I just replaced my whole steering box, it had a leak in it. The shaft looked collapsable, however mine was seized in it's position which made it hard to get the box off/on. We d/c-ed it right up at the top of the column. Hope this helps.
JW-YJ is offline
post #38 of 92 Old 04-01-2010, 08:28 AM
bhartwell59
1987 YJ Wrangler
i think so.
i'm trying to do the bearing replacement w/o dropping the box... and would rather disconnect it at the bearing or lower shaft coming out the firewall.
i've been liquid wrenching it at the middle point on the intermediate hoping to get it to collapse... i wanted to know if it's ever going to.
if not i'll just drop the box and take it from there.
thanks.
post #39 of 92 Old 04-14-2010, 10:59 AM
SDGBASSE
Great write-up, by the way, the collapsing is necessary on the steering shaft, it prevents the steering from impaling the driver when in a frontal crash.....
Originally Posted by ZeroGravity View Post
I didn't click the link because it says "power probe" in the url.
SDGBASSE is offline
post #40 of 92 Old 04-14-2010, 12:26 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
I wonder how much force it takes to collapse it, since everyone seems to have problems with that.
I never thought dropping the box would be a problem Mine has no rust at all but I can see now that rust may be a problem... However I do not know what is more difficult, getting the shaft to collapse or removing the rusty bolts at the frame.
Great write-up
Thank you
Fernando is offline
post #41 of 92 Old 04-14-2010, 03:13 PM
SDGBASSE
I haven't replaced one yet, but from what I understand it should be pretty easy to move (when it's brand new), after a couple of years of usage it probably jams in place if it's not lubricated frequently. But a frontal crash should be enough to free it...
SDGBASSE is offline
post #42 of 92 Old 04-14-2010, 03:32 PM
Opihi59
from here it gets rough
Opihi59's Avatar
My steering shaft was fused together and would not slide/telescope. I PB'd it over a few days then removed it and "encouraged" it to slide, then took it apart and greased it up. Slides real well now.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #43 of 92 Old 08-05-2010, 06:05 PM
g4x4xgeoff
it's really not fair hwo clean your frame is...
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #44 of 92 Old 08-05-2010, 06:26 PM
Goldneye
Nice wright up, and tiled floor to boot
Goldneye is offline
post #45 of 92 Old 08-06-2010, 05:36 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Haha thanks!!
Fernando is offline
Lower Steering shaft replacement EnFuegoUno YJ Wrangler Technical Forum 14 10-24-2009 08:15 AM
Lower Intermediate Steering Shaft Pics cntryboy JK Wrangler Technical Forum 0 05-20-2009 11:43 AM
Steering Shaft and Bearing Replacement ech0sh4y YJ Wrangler Technical Forum 6 11-18-2008 10:09 PM
steering column lower bearing replacement azgurney YJ Wrangler Technical Forum 10 03-18-2008 07:12 PM
how to replace lower steering shaft & bearing??? raStapiMpjaY YJ Wrangler Technical Forum 0 04-02-2006 02:51 PM
